replacing everything
Old Sep 20, 2001 | 05:15 PM
White_Boii's Avatar
im basically doing an engine swap, but im doing like everything else, so just hear me out, maybe one of you smart people can help me out. there is a tube that looks like its going to a cannister in the engine bay (front drivers side) that seems to be comming from the brake peddle, what is that? do i need that? also the speedo cable, where does that go? stupid question maybe but i had cruise and i dont want it anymore, and i need to know if i need to get a new cable, or just re rout the one from tranny? thanks guys!
1983 Camaro Berlinetta
CAME WITH: 2.8L V6, 700R4, no mods, black with red fullsize stripes.
WILL BE: 5.7L V8 with about 400HP, TH350, white with blue stripes.
Old Sep 20, 2001 | 05:19 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
If the tube is coming from the brake pedal area, I would guess it is for the cruise. I'm not sure how the cruise works on an 83, so I can't really comment on the speedo cable issue.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust,Dynomax Bullet Mufflers, T&R Motorsports custom air intake
Old Sep 20, 2001 | 05:23 PM
White_Boii's Avatar
you are so right about the tube!! thank you so much i didnt even think about that!
Old Sep 20, 2001 | 06:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, it cuts the cruise when you tap the brake.
If you want to take the cruise govenor out, you'll need a non-cruise speedo cable from the tranny up to the speedo, or a cable from a later car with ECM-controlled cruise that had the cable go directly from tranny to speedo (not sure when that started, but I know '86 had it).
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
