Air pump removal and stock belt
Old Jul 11, 2005 | 06:10 PM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
ok so i found a belt routing that works with the stock belt (its a little tight but it works)
heres a drawing (yes i suck at MSpaint)
LMK wat u think, or if this would cause any problems.
Old Jul 13, 2005 | 03:32 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I think thats in one of the tech articles about how to remove your AIR/Smog pump..
Old Jul 13, 2005 | 01:27 PM
Borsty's Avatar
Car: 89 Trans am
yes but for the article u needed a new belt and the routing when from the alt to the ps pump to the wp.
Old Jul 13, 2005 | 07:29 PM
duz's Avatar
duz
Car: 82 Firebird
Engine: 5.0
Transmission: 3 speed auto
reminds me of some kind of brain teaser puzzle. i'm probably wrong, but won't that make the water pump pully rotate backwards, or does that matter?
Old Jul 13, 2005 | 07:55 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Would it matter, yes. Does that belt routing spin the water pump backwards, no.
Good job, Borsty. How's that belt routing working out so far on your car, or have you driven with that routing yet?
Old Jul 14, 2005 | 04:26 AM
Borsty's Avatar
Car: 89 Trans am
i havent started the car up yet, brand new engine and i just test fitted it, for kicks saying 'hey why not nothing to lose, and bam it fits, everything turns the way it should, in theroy.
oh yeah, never put vortec heads in place of regular SBC heads once were big big big PITA
Old Jul 15, 2005 | 10:48 AM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
How does the idler sit? Does it look normal or does the pulley sit lower?
Old Jul 15, 2005 | 11:00 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You should be okay but I would monitor your water pump. It may slip seing how you sped up its rotation with less torque applied to it. The alternator pulley is smaller than the PS pulley.
Old Jul 15, 2005 | 12:56 PM
Borsty's Avatar
Car: 89 Trans am
its a little higher, its a tight fit.
Old Jul 16, 2005 | 02:06 PM
theMachinist's Avatar
Car: It was a 90' firebird formula
Engine: It had 357 tbi
Transmission: Was 700r4 auto
Axle/Gears: Was 2.73
i just now put that setup with the belt on my 90 formula, and the car runs fine but now i have a coolant leak, its driping from arond the timing chain cover, looks as if its coming from the water pump, i think maybe its from the different belt routing, because the way the belt pulls on the water pump is in a different direction from the stock way, plus now i cant use my air because when the clutch kicks in the belt slips around the crank pully, and squeals real loud and the belt stops. but as long as the clutch doesnt kick in in runs fine. ill try and post a pic of it later today.
Old Jul 16, 2005 | 02:27 PM
vrtc350's Avatar
Car: 81 Corvette
You mean the belt stops moving completely?
Old Jul 16, 2005 | 05:40 PM
yeah completly, because if you look at the amount of area that the belt used to touch the crank pully when stock, that area is almost cut in half. so the belt touches on about 1/3 of the crank vs. 1/2 the crank. thats why if you look at the tech artical that was posted the guy said to get a longer belt so that you can route the belt so that it touchs the same amount of area on the crank pully as before.
Old Jul 16, 2005 | 07:28 PM
vrtc350's Avatar
Car: 81 Corvette
Do you know what length, or who knows what length? This is going to become an issue real fast for me//. I just got the hugger orange on my engine, now I'm cleaning up the serp brackets.
Old Jul 17, 2005 | 10:07 PM
You will however need a longer belt, I used Dayco 968K6 belt. It is basically a 96.8" 6 rib belt. All parts stores stock just about every length of belt in every width. They should be able to find it using these numbers. If you have an underdrive pully you will need Dayco pn# 935K6 which is actually shorter than the stock belt by one inch.
this was posted in the tech artical, he said to use a 96.8 in belt.
Old Jul 17, 2005 | 10:19 PM
vrtc350's Avatar
Car: 81 Corvette
It seems hard to understand that taking the stock route while eliminating the smog pump you would need a longer belt. You don't have to take that trip down the smog pump which is below the a/c.
But, with the been there and done that thing. I will take others learning experiances and profit. Was that tech article on TGO?
Old Jul 17, 2005 | 10:24 PM
https://www.thirdgen.org/newdesign/t...rpentine.shtml
thats the link that was givin to me.
Old Jul 17, 2005 | 10:50 PM
vrtc350's Avatar
Car: 81 Corvette
okay, I see. He is going from the altenator to the power steering pump, water pump, crank, back to the a/c. The longer belt allows you to route this way and give the necessary contact to the crank.
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 8, 2015 07:09 PM
