had my heads flowed = (
Old Jul 13, 2005 | 07:26 PM
daverr's Avatar
i bought a used set of brodix -10 ri cylinderheads.I Had the cylinderheads flowed.here are the numbers.
intake exhaust
2.100(not sure) 1.60
.100 73 65
.200 138 117
.300 201 175
.400 251 206
.500 266 219
.600 259 225
.650 257
.700 255 226
Brodix catalog shows this head should be closer to 300 cfm.
good thing i didnt buy new.there is some bowl work but thats it.
we `re thinking that if we open up the intake ports up ,it will improve the flow numbers. I recommend anyone who buys cylinderheads new or used to haved them flowed , saves the disapointment at the dyno.
i should of went to 18 degree cylinderheads
Old Jul 13, 2005 | 07:33 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Dart is the biggest mis representer in flow numbers from what they "claim" to what they actually flow. Brodix has had a pretty good reputation from the few guys I've talked to, but obviously if your catalog claimed them at 300cfm and they only 260cfm...that's roughly about .4 on the track and a huge loss in potential hp.
AFR is expensive, but at least what they advertise is what you actually get.
Old Jul 13, 2005 | 07:50 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
Just curious if you flowed them at the same inches of water as what brodix used? (ie 28")
Old Jul 13, 2005 | 07:52 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: had my heads flowed = (
intake exhaust
.100 73 65
.200 138 117
.300 201 175
.400 251 206
.500 266 219
.600 259 225
.650 257
.700 255 226
HELLO!!! the flow chart is for a head with a specific CNC port job (you can assume safley that it has the most $$$extensive preparation package$$$, with the largest valves.
Your heads have " some bowl work" Not the same thing.
Once your heads are prepared like the ones in the test, they will flow the ###'s
Doesn;t matter if its AFR, Dart, Brodix or World Products, if you want the CNC package flow numbers the heads have to be CNC ported (with the same CNC Program and valve contour.). Ya get what you pay for.
Old Jul 13, 2005 | 08:23 PM
daverr's Avatar
Re: Re: had my heads flowed = (
i know theres the cnc heads but these heads are the regular Raised runner heads.Which states it closer to 300 cfm.
heads were flowed with 28" drop
Old Jul 13, 2005 | 08:30 PM
daverr's Avatar
Afr
i still have them flowed.too many sales pitch out there.
Old Jul 13, 2005 | 09:27 PM
IHI's Avatar
IHI
Re: Afr
I totally agree, and was another reason I had them flowed-alot of other reasons actually. When I told the guy at the shop what these AFR's were supposed to flow, he looked them over, snickered and guessed 260cfm max. Once they were done I went back out with my AFR catalog with the marketed flow numbers, showed him before ever seeing my sheet and he was amazed.
Nice to know once in awhile you actually get what you pay for. There are other racers I talk to that own machine shops and have had the same findings with all above mentioned brands so it's not just a few guys and a rumor mill-it's just a fact, just like Holley over rates the flow on their carbs...marketing ploy.
Old Jul 13, 2005 | 09:58 PM
daverr's Avatar
well according dd2000 (which i do not believe in).i plugged in the head flow numbers .this is what it predicts.
644hp@6500 609tq@5000 keep in mind this is a high compression motor (14+:1)
using head flow numbers 266*.2575*8= 547.96hp
motor is still at machine shop.It will be run on a engine dyno in about a month.i wonder which prediction will be closer.
Old Jul 13, 2005 | 10:15 PM
IHI's Avatar
IHI
That should be very interesting. I took all my values form my stuff and entered it into my DDyno and it came up with 575hp. I wanted to dyno the motor, but did'nt have the time as racing started within a few weeks of drivetrain swap. I am going to chasis dyno later this year for fun and that should give a closer indication of what the motor is actually putting out....but after 2 years of racing and street miles I'm sure the power will be a tad lower due to valve springs being worn and rings wearing a little...still be fun though.
Let us know how you come out, would be nice to see computer estimate with real world. Just be sure to get the air data from the shop so you can match the air on the simulator as closely as possible to the dyno room.
Old Dec 5, 2005 | 11:55 AM
daverr's Avatar
New setup
Well decided to trade up the Brodix -10x for the Brodix 18.I still
need to buy the valves,springs,retainer etc.I will have these heads Flowed. Here are some pics.
Old Dec 5, 2005 | 12:00 PM
daverr's Avatar
More Intake pics
Fuel Injection system is a DFI GEN 7 WB SEQ
Old Dec 5, 2005 | 01:03 PM
Guest
Guest
Posts: n/a
The guy who does my machine work almost always uses Brodix heads. He did say, and I have read and heard this elsewhere, that they generally need to be ported to flow well as they dont flow well out of the box. That applies, I'm sure, to non-CNC'd heads.
Nice intake. PT elbow?
Old Dec 5, 2005 | 01:13 PM
Vader's Avatar
Re: Afr
...too many sales pitch out there.
Which is why a TB air foil is "good for 10-15HP" and intake "Tornado" makes more MPG...
Why shouldn't they? Everyone else over-rates Holley carburetors. It's free advertisement for them.
Old Dec 5, 2005 | 07:26 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
There are lots of variables that have to be taken into account as far as a flow test go. What bore size were the heads flowed on? Were they flowed with or without a pipe on the exhaust? What size pipe? What about a radiused entry on the intake? Not to mention every bench is different and so are the operators processes.
I hope you plan on spinning that motor pretty high with that intake setup and have a valvetrain that'll support it
Old Dec 5, 2005 | 07:45 PM
daverr's Avatar
PT elbow?
The elbow is from Wilson Manifolds.
My engine builder suggested titanium valves and retainer.
For the rockers we`ll probably go with a crane or jesel setup.
Old Dec 5, 2005 | 08:03 PM
Dialed_In's Avatar
Old Dec 5, 2005 | 08:07 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I imagine he already has the 12K+ RPM tach mounted on the dash
Old Dec 5, 2005 | 10:11 PM
Dialed_In's Avatar
lol, I'm not scared. Dial it in! I got fast shoe polish and I got slow shoe polish
Old Dec 6, 2005 | 02:36 AM
11 Flat's Avatar
Those heads dont flow good because who ever ported them ****ed them up.
The flow is dropping off which is a bad sign.
Old Dec 6, 2005 | 06:37 PM
Dialed_In's Avatar
Unleaded fuel is gonna eat them valves up !
Good luck with your project
Old Dec 6, 2005 | 08:58 PM
daverr's Avatar
This is going to be a high compression motor ,so i`ll be using race gas only.
gta90
Sep 15, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Ducati900ss
Sep 2, 2015 09:05 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
