Checking a timing chain...
Old Jul 19, 2005 | 03:17 PM
POS350Z's Avatar
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
...doing the cam swap...this timing set has about 25K on it...is there a way to inspect the set to make sure it's still up to spec? I looked in the manual and couldn't find anything....also did a search and founde nada....thanks!
350Z
Old Jul 19, 2005 | 03:38 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
Replace it..they are cheap.....get a Summit double roller for the roller block for about $50. At 25K I wouldnt trust it in a high po setup.
Old Jul 20, 2005 | 05:45 AM
CrazyHawaiian's Avatar
Car: too many ...
I haven't verified this yet but I've been suspecting an issue with my timing chain recently and here's a post I found on here:
https://www.thirdgen.org/techbb2/sho...timing+changes
They aren't that expensive but they are a real PITA to change.
Old Jul 20, 2005 | 06:35 AM
ede's Avatar
ede
i wouldn't bother checking, just replace it. use to be you looked for deflection in excess of the chain thickness when you held it sideways.
Old Jul 20, 2005 | 09:49 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Only down side to that is you have to clearence th block a little bit for the double roller gear to fit. Can be harder if the block is in the car.
Old Jul 20, 2005 | 02:39 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I didnt have too.
Old Jul 20, 2005 | 08:43 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Only one I had clearance issues on was the Cloyes piece. I had the Summit double roller and it fit fine. I am running a Comp Cams piece now and it fits fine also....
Old Jul 21, 2005 | 01:10 AM
Tibo's Avatar
Car: 1991 Z28 Vert
I have gotten a summit(s) and had to clearence them three different times.
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 17, 2015 02:52 PM
