Car keeps dieing
Old Jul 24, 2005 | 02:39 PM
1FSTZ28's Avatar
Car: 1989 Camaro IROC Z28
Engine: 350 Stealth Rammed
Car keeps dieing
Ok, I have a 1989 IROC with a 350 in it and the HSR. Ive had the HSR installed professional for about 3-4 weeks. The other day my car starting doing something wierd. Everytime i got on the gas it acted like it wanted to hesitate. So i took it straight home and tried to see if we could figure out what it was. Well i didnt really worry about it that night. The next morning i get up to go to work and i start the car, it starts then after the rpms start to drop so it can idle it just dies. The rpms wouldnt even stay up for more then a couple seconds. Anyone have any ideas? Even when i hit the gas to try to make it stay running, like i said the gas wants to hesitate. Thanks for your help in advance!
Old Jul 25, 2005 | 12:22 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
Did you properly set the idle air control (IAC)? How's your TPS voltage?
Vader has a great write-up on those things; do a search and you should find it.
Check the fuel pressure too, and make sure there aren't any leaks around the regulator and fuel rail.
Old Jul 25, 2005 | 03:39 PM
1FSTZ28's Avatar
Thanks for the advice but i finally got it fixed. It was the MAF sensor. :/ I still have a problem of my idle wanting to drop below 700rpms. I'm going to see what i can do with the idle air control or the actual idle control itself.
Old Jul 25, 2005 | 04:03 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Ahh yes, the good ol' MAF sensor... . I hate those things, haha. Glad to hear that you got (most of) the problem fixed. Let us know how it turns out.
Old Jul 26, 2005 | 03:37 PM
1FSTZ28's Avatar
I'm still getting a check engine light if i drive it for about 15 minutes or so. Anyone have an idea? It didnt start doing it until i installed the new MAF sensor. And also anyone explain to me how to change the IAC. Thanks!
Old Jul 26, 2005 | 04:08 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
What code are you getting?
Are you looking to change the IAC or merely make sure it's adjusted properly? There's really no reason to buy a new one if it's working; try to adjust it first. When I replaced mine, I found it easiest to remove the throttle body from the plenum and use a large socket to unscrew the IAC motor.
Old Jul 26, 2005 | 06:33 PM
1FSTZ28's Avatar
I am not sure HOW to adjust it. That is what i was needing to know. And that is the other problem, i cannot check what code i am getting because for some VERY odd reason nobody can find the ALDL. It is not under the dash. I have no idea what the previous owner has done to/with it.
Old Jul 26, 2005 | 07:25 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Like I said, try doing a
This is the article, by Vader, that I was referring to: https://www.thirdgen.org/techbb2/sho...&highlight=iac
Sucks about the ALDL... any wires to trace?
Old Jul 26, 2005 | 08:05 PM
1FSTZ28's Avatar
Nope. I can't find ANYTHING at all. :/
Old Jul 30, 2005 | 10:25 PM
1FSTZ28's Avatar
I finally found the ALDL. Unfortunetly, when they tried to run a code test it was coming back as a diagnostic error. It would not report a code back. I ordered a new IAC sensor to see if that would fix the problem, and i am going to go from there to see if i cant get this straighted out, once and for all!
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
