Custom Ram Air! Anyone try this?
This is my weekend project. I'm ditching the open element setup, and I'm going to use the dual snorkel air cleaner set up. Then I'm going to route AC ducting to the high beams, which I don't use (HID xenon is more than enough) and make an opening in the empty headlamp sockets I have, and put a small screen over the openings, for a ram air effect. I saw this done on a Chevelle in Car Craft...has anyone else here tried this?
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot)
Dynomax cat-back exhaust
Hedman headers
K & N open element/ X-Stream lid
MSD 6A ignition
MSD 8.5mm plug wires
LT1 camshaft
Soon to be installed:
Edelbrock intake manifold
B & M 2400 RPM stall torque converter
Trans Go shift kit
World Products Torquer heads
Audio
Sony Xplod CDX-M610 head unit
Pioneer 2-way 4x6 front speakers
Pioneer 3-way 6x9 rear speakers
12 inch Pioneer VCCS PRO subwoofer
QLogic sealed box
Kicker ZR360 amplifier
Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay
A-pillar gauges (Phantom oil pressure, Air/Fuel)
180* thermostat
Window Tint
Performance mods
NOS (125 HP shot)
Hedman headers
MSD 6A ignition
LT1 camshaft
Trans Go shift kit
Audio
QLogic sealed box
Other
180* thermostat
Window Tint
Well..yeah. Probably hundreds of people have done that. It works fine, but the gaping hope where the high beams used to be gets to be kind of an eyesore after awhile. Just a matter of taste I suppose.
I'd use the fog light holes. They're more hidden. Also, THE MAN (law) may have something to say about no high beams. That depends on whether you have inspections in your state.
Jeff
'85 Berlinetta, Special Beater Edition
Mods include a 4bolt 350 with 280*, .460 lift cam, Vortec heads, Comp Cams roller tip rockers, Edelbrock TES headers, no other exhaust
. Also, rusted parts on all 4 corners, and crumpled fenders, thanks to the previous owner.
Jeff
. Also, rusted parts on all 4 corners, and crumpled fenders, thanks to the previous owner. BahamutRS
How does that 125 shot work and how much did it cost.. I was lookin into it but someone said 799.. I said,.. no thanks
92 Camaro 305 TBI Automatic
2.5 high flow cat, 2.5 pipes, 3.5in tip
shift kit
Tinted windows(legal)
Spark plug wires and plugs...
14X3 O.E. K&N Filter
Future mods.
Headers
any other advise on getting to 300+ HP would be appreciated. Thanks
11.0 Et @64mph on the 1/8 reaction time was 1.0+ with a 60ft at 2.5?(First run ever, didn't know which light to go on)
System = Sony explode 5000 CD/MD receiver
Rockford 6x9 Fanatics
Rockford 4x6 Fanatics
Rockford 2 12" Hx2's
Rockford 1 farad cap
Rockford 800x2 Amp
Custom box
4gauge wire kit
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=6100
shift kit
Future mods.
Headers
Rockford 800x2 Amp
Custom box
4gauge wire kit
ya im pretty sure that wouldn't pass inspection. unless they don't test that there,
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
- David
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
