Which metering rods are the secondaries?
Old Aug 4, 2005 | 09:15 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I know that there is something im looking over to answer my question. I got an Edelbrock 1406 carb, and there are the two rods that are removed at the top of the carb. Is one of these the primary and one the secondary? IF so which is which?
Old Aug 4, 2005 | 09:20 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
They are BOTH secondary metering rods. One for each "barrell".
Old Aug 4, 2005 | 09:21 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Which ones are the primary?
Old Aug 4, 2005 | 09:26 PM
ploegi's Avatar
Engine: 5.7 TPI
There are no primary metering rods. Primary circuit is always in use, and are simply jets at the bottom of the fuel bowl.
They are referred to as "secondary metering rods" because they meter fuel for the secondary circuit. (clear as mud????)
Old Aug 4, 2005 | 09:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Other way around. The primaries have metering rods, the secondaries don't.
Old Aug 4, 2005 | 09:32 PM
ploegi's Avatar
Engine: 5.7 TPI
Uhhhh, 'scuse me??? THen why are the rods on the back two barrels of the carb? Why do the rods move when the secondary butterflies move? (and not when the primary are opening?)
I know that some carbs with the MC solenoid DO have metering rods on the primarys as well, but, I dont think that is the case here.
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
So what your saying is, to tune the primaries, change the rods and to tune the secondaries, change the jets?
Old Aug 4, 2005 | 09:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Because it's an Edelbrock, not a Quadrajet.
Quadrajets have metering rods on both the primaries and the secondaries.
Old Aug 4, 2005 | 09:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
To tune the primaries, you can change the rods and/or the primary jets. For secondary tuning, you change the secondary jets.
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
ok, thanks
ploegi's Avatar
Engine: 5.7 TPI
Ooops, my bad. Used to the old style......... Went looking, and you are quite correct. Sorry 'bout that.
RS Reaper
Oct 17, 2018 07:52 PM
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Oct 5, 2015 06:23 PM
