Can anyone ID this valve seal?
Old Aug 4, 2005 | 10:00 PM
87350IROC's Avatar
Car: 87' IROC
Anyone know what style valve seal this is?
Old Aug 4, 2005 | 10:14 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Hidden.
Old Aug 4, 2005 | 10:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
From the tiny sliver of white, maybe teflon, or teflon sleeved. Can't say for sure without taking the spring off though.
Old Aug 5, 2005 | 11:19 AM
87350IROC's Avatar
Car: 87' IROC
they are supposed to be teflon
Old Aug 5, 2005 | 10:14 PM
87350IROC's Avatar
Car: 87' IROC
so if they are teflon seals, what are my options for replacement, assuming i don't want to do any more machine work
Old Aug 5, 2005 | 10:18 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you're going to replace them, it doesn't matter that they're teflon. Just get replacements the same size made out of whatever material you prefer.
Old Aug 5, 2005 | 10:22 PM
87350IROC's Avatar
Car: 87' IROC
what i mean is i know some different kind of seals require machine work on the heads, is this true of teflon seals? or does it vary? I don't want to do more machine work, i just want to replace the seals, so i'm trying to figure out which ones I can just plug and play
John
Old Aug 5, 2005 | 10:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Teflon is just what it's made out of. There are rubber seals that need machining too. Chances are that it's already been machined, but you'll still have to take it off and measure the valve guides to see if it has, and to what dimensions.
Old Aug 5, 2005 | 10:58 PM
87350IROC's Avatar
Car: 87' IROC
I thought maybe all teflon seals were the same size. I'm going to take a spring off tomorrow, I'll do some measurement then and snap some pictures.
Thanks for the help
John
Bubbajones_ya
Jul 6, 2024 08:32 PM
355tpipickup
Sep 13, 2015 11:35 PM
bamaboy0323
Sep 12, 2015 07:14 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
tgp1990
Sep 4, 2015 06:24 AM
