high-flow edelbrock base, have questions!!
Old Aug 6, 2005 | 04:13 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
so i have a edelbrock tpi base that im goin to be puttin on my 91 tpi motor, ive been told that one of the bolts needs to be sealed because it goes into the water jacket, is this true? if so what bolt is it? i guess what im askin is what will i have to do different for instalation for this edelbrock base over a stock base? need to know asap!!! thanks
Old Aug 6, 2005 | 07:39 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
I use sealer on all of them, but that's just me. Make sure you RTV around the coolant ports on both sides of the new intake gaskets
Old Aug 6, 2005 | 11:53 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Old Aug 7, 2005 | 11:38 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
The driver side rear runner mount, bottom hole needs to be sealed. Rest are closed.
Old Aug 7, 2005 | 11:42 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Maybe according to Edlebrock, but why would a stock base seep through just about any/all the holes?
Issue to seal isn't with the intake holes, but with how your heads are manufactured and where the bolts go to.
Seal'em all.
Old Aug 7, 2005 | 11:44 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Were talking about runner bolts here. Not intake bolt. You need to seal ONE RUNNER bolt, which is the one I mentioned above.
Old Aug 7, 2005 | 11:48 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Hmmn...original poster says "so I have an Edelbrck TPI Base"...where did runner's come into it.?
If so, must be an Edelbrock thing, definitely..I can't count the number of GM and Aftermarket TPI runners I've put on, all without any sealer at all.
Old Aug 8, 2005 | 12:02 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Errr...always sealed the bases...not the runners.
Old Aug 8, 2005 | 11:24 AM
Engine: LB9/383
werd. Never sealed any runners here either. May have to start.
Old Aug 8, 2005 | 11:30 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Well I always seal the base, but that one hole leaks antifreeze when I take it out the driver side runner. It even mentiones it in the directions that come with the manifold. Now, my manifold is about 4 years old so their may be a new casting now or something that solves this problem.
beastin91rs
Oct 9, 2015 07:38 AM
fasteddi
Sep 2, 2015 10:29 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
89-S-dime
Aug 12, 2015 11:57 AM
