high oil pressure
Old Aug 7, 2005 | 08:39 PM
blackgta1989's Avatar
high oil pressure
After getting all my mods done to my car my oil pressure is running 60 above is that bad? I'm thinking that the gauge broken ? Please help me out thanks
Old Aug 8, 2005 | 06:25 AM
Vader's Avatar
Rather than trust the dash guage, you could verify its accuracy with a separate guage.
What "mods"? Moreover, what viscosity lubricant is in the sump?
Old Aug 8, 2005 | 01:07 PM
luke4907's Avatar
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
You might want to check the wiring and connectors for that sensor as well. I know mine is rigged together, and my gauge bounces around quite a bit. If the sensor wire gets grounded to the block or your exhaust (headers that may have melted the sensor wire?) etc then I think the gauge is gonna read 60+ all day.
Old Aug 8, 2005 | 04:38 PM
mods from
SPDC Vortec Head Kit, Roller, TPI Intake, Headers
1.6 rockers arm
molly pushrods
Edelbrock short headers
zz4 cam
comp cam lifters
Where is sensor wire at? Do you have a pic?
Old Aug 8, 2005 | 05:37 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
it should be on connected to the oil pressure sending unit which should be located on the divers side rear right by the back of the intake manifold a tad right of the driver side head.
Old Aug 8, 2005 | 09:14 PM
ok i put a new one thanks for your help
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
