305 crnk bolt?
Old Aug 8, 2005 | 10:07 AM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
305 crnk bolt?
Does anyone know the specs on the crank bolt for an 85 305 motor? I bought one but it has a fine thread and does not fit, an old head bolt I have worked better, but still was not correct. I'm thinking i might have to tap the hole, or at least chase the threads, but I dont want to use the wrong one.
Old Aug 8, 2005 | 10:49 AM
ede's Avatar
ede
if an old head bolt worked better the threads are screwed up. all SBC crank bolts are 7/16-20
Old Aug 8, 2005 | 11:32 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
ditto
Old Aug 8, 2005 | 01:32 PM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
Did you take the flywheel off with a puller?
Sometimes the puller can damage the first few threads on the crank.
Take your old crank bolt and file the first few threads down to taper the end. Then gently start it in the crank. If it goes in ok turn it a few times and that should fix the threads.
If it doesn't chase it with your tap slowly to be sure you are engaging the original threads.
84z96L31vortec
Aug 20, 2017 12:16 AM
Dwayne614
Sep 28, 2015 08:33 AM
Cleotiz
Aug 22, 2015 01:54 PM
theurge
Aug 21, 2015 12:46 PM
