Difference between RW dynos and engine dynos.
Old Aug 9, 2005 | 03:09 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Has anyone dyno'd their engine out of the car and in it. Not in theory, or 15-20%, but real life numbers? If so, what were they?
Old Aug 9, 2005 | 05:02 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Quite often the engine dyno will not have all the accessories hooked up and some use an electric water pump. So things will be even more skewed in favor of the engine dyno.
So one would need to know the particulars of the engine dyno to calculate the drive train losses. That would be one reason the percentages would vary somewhat.
Old Aug 9, 2005 | 11:57 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Dynos are so inaccurate that it doesn't really matter. Dynos are only good for relative purposes such as tuning.
Old Aug 10, 2005 | 12:00 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
An engine dyno will also have a completely different exhaust system, and an unlimited supply of cold air.
Old Aug 10, 2005 | 07:30 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
so no real life numbers?
Old Aug 10, 2005 | 10:39 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What is it you're trying to figure out?
Old Aug 13, 2005 | 12:02 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
I think he's try to figure out how much parasitic loss difference would result between a dyno run on an engine dyno followed by another run on a chassis dyno. The answer isn't very clear cut. A lot of things can affect the parasitic loss factor. There isn't a specific parasitic loss percentage other than the 10-35% generalization you'll usually get. I'm with ME Leigh on this one. The dynos good for tuning and maybe general numbers but not much else.
Old Aug 13, 2005 | 01:52 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
I was going to try testing that but when I thought about it, it wouldn't be accurate. Just like as stated above, no accessories, different headers and exhaust, no intake. We've got an engine dyno here at teh shop and where I work part time we have a chassis dyno so I may do the comparison anyway but it wont make a difference. Dynos are for tuning. Not to mention every dyno is different, so is every operator and their procedures.
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
