would this work?
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
would this work?
ok, so i am going to get a new engine, just have a few questions. i am planning on getting this engine, it is a 350h.o. my questions are. would i be able to use the computer off of my 305 and could i use the same throttle body and intake?
future engine?
future engine?
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Re: would this work?
future engine?
future engine?
the computer from the 305 won't work unless you put a chip in it for a 350 or a custom burnt which is what i believe you'll be needing to run this engine properly. the intake will work but you'll need bigger injectors since the 305 uses smaller injectors than the 350. other than that though most everything else should work fine. good luck.
how are the intakes different? i couldn't use the one i have now just untill i get a new one?
Engine: 355
Transmission: 4L60
the bolt angles are different on 87 and later heads and so on but i always thought the tpi intake bolted to vortecs but i could be wrong.
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
When I laid the stock TPI intake between my new fast burn alum heads , there was a gap of no less than a 1/4", I would clasify tha t as a huge leak.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I repeat you can only put a Vortec intake on vortec heads. No way around it unless you want to weld 1/2" of aluminum to the top of every port.
You can't do it. Vortec heads are different than centerbolt heads which you are referring to.
Car: 88' IROCZ
Axle/Gears: 2.77
The head in the images below ia a GM Fast Burn Aluminum head P/N 12464298. As can be seen it has dual intake bolt patterns, as well as center, and rail valve cover bolt patterns.
I bought a Scroggins-Dickey High-Flow Vortec TPI baseplate (intake) P/N 12498060 to top it off.
GM Technical Note for the Fast Burn head:
Use intake manifold P/N 12496820, 12366573, 12496822, or 10051103 with the Fast Burn cylinder head.
These are all Vortec intakes. Which means that the Fast Burn head, incorporates the Vortec design.
ok so i can't use the stock intake, but would the motor mounts line up? or would i have to fab my own?
Car: 82 Z28
Transmission: TH350
yeah i switched the topic, since we came up with the answer to the intake instead of making another thread i just asked about the motor mounts on here. lol, it will be ok
Terrell351
Jun 13, 2021 01:13 PM
