building a 334 is it worth it??
Old Oct 10, 2001 | 10:15 AM
92zeddar's Avatar
I was wondering if it is worth building a 334 stroker 305 engine what are the pro's and con's of it and where do i find a kit I could by to do the whole engine? or just find a 400 crank and go from there..
Thanks guys
92 z-28 G92 black with white racing stripes.
Dynomax cat back
Ram air
305 5 speed, underdrive pulleys and TB by pass
Old Oct 10, 2001 | 10:44 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Pros:
Cons:
Costs more than a 350
More work than a 350
Slower than a 350
You do the math
ICON Motorsports
Old Oct 10, 2001 | 10:54 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
LOL!
Old Oct 10, 2001 | 02:08 PM
iroc5speed's Avatar
haha that;s pretty funny.
true though
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Old Oct 10, 2001 | 02:34 PM
Jester's Avatar
LMAO!
But yeah..I agree
Old Oct 10, 2001 | 02:56 PM
Biochem's Avatar
Car: 2002 SOM z28
<font face="Verdana, Arial" size="2">Originally posted by 92zeddar:
</font>
I don't know... how valuable do you consider "pissing into the wind"?
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Oct 10, 2001 | 03:45 PM
Kyle F's Avatar
you guys forgot something... a 334 will have a lot more torque than a 350. IF you are bulding a motor to pull a trailor it would be ok, but for speed you need a larger bore.
Longer stroke = more toque
Larger Bore = more HP
Though more displacement = more hp and more torque
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Oct 10, 2001 | 04:26 PM
Killer-Z's Avatar
It is only worth it if you want to be different. Later Derrick
Old Oct 10, 2001 | 04:29 PM
Killer-Z's Avatar
Old Oct 10, 2001 | 06:41 PM
breathment's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Kyle F:
</font>
doesn't a 383 have more torque then a 334
Old Oct 10, 2001 | 07:03 PM
irocbsa's Avatar
Dude, If you want to have something that most everybody else doesn't then by all means go for it, and don't listen to the people who discourage you, just the ones that encourage you. You could make decent power with it and it'd be kinda cool to probably be the only guy in the damn state with a 334. I personally think folks that go the unconventional route have more ***** and ingenuity. But sometimes practicality outweights ingenuity by so much that you start to tread on the fine line of insanity.
But, if you want to go for a cheap, reliable, combo that makes great power the 350 is the way to go, no question. Ease of maintenance and more than plentiful parts. Bottom line, do what you gotta do.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
1991 RS, 305 TBI, T-5, Bone stock daily driver.
Old Oct 10, 2001 | 08:03 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
you guys forgot something... a 334 will have a lot more torque than a 350. ... Though more displacement = more hp and more torque
</font>
It really depends on the setup but a 334 also has less displacement, so it may not even make more torque depending on head/cam/intake choice.
The ONLY reason I would build a 334 over going with a 350, would be to retain a numbers matching block if you believe that your car will have "collector value". Other than that, I too say "go 350...better yet 406"!
[This message has been edited by Glenn91L98GTA (edited October 10, 2001).]
Jorlain
Oct 8, 2015 01:57 AM
R13_Braz
Sep 18, 2015 05:00 PM
Badjuju
Sep 16, 2015 05:43 PM
Blkdth87
Sep 16, 2015 01:40 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
