305 Performance
305 Performance
What are the best things to do to a stock 305 ci V8 L03 engine with stock tranny in a '91 Camaro RS with out replacing either? I have read all the tech artivles and all that stuff, and was hoping for some community input.
Car: 4
Engine: 6
Transmission: 5
In this order: exhaust from the heads to the street; cam; "real" (not stamped sheet metal) rocker arme; and heads.
Get a set of application-specific headers such as Edelbrock TES, SLP, or Dynomax, that come with a Y-pipe; and a new cat; and a cat-back exhaust. DO NOT get the ones for the L03, because if you do, they will all contain the same restriction you now have. Get the ones for a TPI 350.
A decent cam would be something around 210°/220° to 215°/225° at .050" lift, something like a Comp 264HR. Stay under .500" total lift. For rocker arms, a good "bang for the buck" is the Comp steel roller-tip ball-fulcrum units.
ICON Motorsports
ICON Motorsports
RB83L69, how much (approx.) would what you just mentioned cost me? and second: (yes, I am kinda new to the car thing, got a friend that aint, that will help me), would stuff, like heads and headrer, that say 'for 350ci' work with my 305?
For the cat-back system, you would be looking at about $250 or so, depending on who you get it from, or a little over $500 for the awesome Borla kit. Go stroll over to www.jegs.com or www.summitracing.com and look at some of the exhaust crap over there, and you can get an estimate of how much it will cost. Some of the costs will vary widely, depending on the name brand that you get. But please get the kit for the 350 engine, not the 305!
Actually, you may just want to drop a 350 in there to begin with. But it's really up to you, and how much time and money you are willing to put into this and how much hp and torque you want in return. I'd get the 350 though
Take a look at some of what I did. I made sure everything I bought would bolt right on to a 350 for when I feel the need. Thats why I haven't bought heads or a cam. Everything else will carry over except for the hypertech chip and maybe something else in my sig.
Bugs
91 Z28 305TPI 5spd
Hypertech Stage II, EB Intake & Runners, Ported Plenum, EB Headers, 3" Cat, 3" FM Catback, 1.6RR's, 3.42gears, B&M Ripper Shifter, MSD Wires/Cap/Rotor/6AL, AFPR, Air Foil, K&N's, Gutted Airbox, TB Bypass, platinum plugs, and 160deg Stat.
Bugs
91 Z28 305TPI 5spd
Transmission: 4L80E/4L80E
<font face="Verdana, Arial" size="2">Originally posted by Buck268:
RB83L69, how much (approx.) would what you just mentioned cost me? and second: (yes, I am kinda new to the car thing, got a friend that aint, that will help me), would stuff, like heads and headrer, that say 'for 350ci' work with my 305?</font>
A roller cam will run you about $175-250. The "real" rockers RB talks about, ~$300. Headers, from about $325 to $450, depending upon what you get. High-flow cat, somewhere between $70 and $140.
After all that, you'll probably benefit from a larger throttle body and injectors, and PROM work.
Except for the heads, aftermarket parts made for a 350 will fit your engine.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Do remember that after you replace the cam or the heads you will have to get a new PROM, that MAP run system will fall on its face with those kind of mods.
1 5/8 Hooker Competetion Headers, custom y-pipe,no cat, modified Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat, BF G-Force w-rated tires
