plug wire routing
Old Aug 16, 2005 | 04:24 PM
DanTheMan_smlk's Avatar
plug wire routing
how do i know if my plug wires are going to the correct cylinders? Where can i find a diagram on the internet. Please help
Old Aug 16, 2005 | 04:51 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Get a Hayne's maual you can use it for everything . On the web go to autozone you should find it there under spacific car . If the #'s are on your cap the cylinder's go like this . Driver side 1,3,5,7 seven being by the fier wall . Pass side 2,4,6,8 nuber eight by the wall agian . When running the wier's try to keep 5&7 from crossing . Good Luck .
Old Aug 16, 2005 | 05:19 PM
gearrrhead's Avatar
Car: 1990 iroc
Engine: 350 tpi
if facing the engine compartment the firing order is 1-8-4-3-6-5-7-2 in a clockwise order. cylinder number one is usually at about 5 oclock but because of timing that is just for reference. pasenger side is 2,4,6,8 driver side is 1,3,5,7. 7 and 8 closesest to the fire wall.
you have to make sure you know which post is #1 once you know this it is easy as pie. without knowing this you are screwed.
Old Aug 16, 2005 | 08:30 PM
so how do i find wich post is #1? I looked in the manual and the order is there, just not sure which post is #1...will it say it on the dist?
Old Aug 16, 2005 | 08:45 PM
Marc8090's Avatar
Car: 90 IROC-Z
Engine: 383 Miniram
Turn the engine over until it is at 0* timing on the balancer. Take off the distributor cap and see what post the rotor is pointing closest to. If it's pointing towards the firewall, it's pointing at number 6, rotate the engine one turn to bring it around to #1. Run the plug wire for cylinder #1 to that post, and go around in the previously mentioned firing order.
Old Aug 16, 2005 | 08:57 PM
omg..... i dont have a timing light, there's no easier way? Wont it dump a bunch of fuel in the engine if i keep cranking it?
Old Aug 16, 2005 | 09:41 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
I do not know If your car has a little cover ontop of the distributor cap . If it dose it has the numbers . If you are changeing the wire's do one at a time . If you have no wiers on it now look at the cap . Hold it out in front of you make sure that the reciver connetion is on the right . Now the 2 posts on the bottom are 1&8 one being on the right at 5 o'clock 1-8-4-3-6-5-7-2 clockwise .
Old Aug 16, 2005 | 09:50 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Old Aug 16, 2005 | 09:55 PM
wow...this is so beyond my capacity. I rearranged all the wires and now the car doesnt start well, i dont want to crank it all the way cause it sounds like crap.
Old Aug 16, 2005 | 10:29 PM
how do i find out what cylinder goes to each post
Old Aug 16, 2005 | 10:40 PM
if i dont get help, i will have to tow it
Old Aug 16, 2005 | 10:52 PM
gearrrhead's Avatar
Car: 1990 iroc
Engine: 350 tpi
calm down first. you can bump it over with number one plug pulled and wiat for compression. you could always pull the valve cover and role it over by hand and just watch for the number 1 intake valve to open and as soon is it closes you are close to TDC. you do not need a timing light. where ever the rotor is pointed is post number 1. then clock them 1-8-4-3-6-5-7-2
Old Aug 16, 2005 | 11:22 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Why don't you just follow the picture I posted? Run the wires JUST like in the picture. Here I made it easier for you:
Old Aug 16, 2005 | 11:32 PM
obviously the rotor has been moved by the previous owner so that picture doesnt help because i already tried that
Old Aug 17, 2005 | 12:00 AM
took the cap off and got the correct order, thanks guys
Old Aug 17, 2005 | 01:17 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
ROFL!
eightsixseven
Dec 16, 2024 01:50 PM
Thornburg
Aug 30, 2015 08:05 AM
g.l.mos
Aug 22, 2015 12:02 AM
djmarch
Aug 19, 2015 12:07 PM
