Options for a smaller engine swap?
Car: 95 Camaro Z28
Transmission: 4L60E w/ shift kit
Axle/Gears: 3.23s
After the increase of gas prices and insurance, and the cost it'll take me to restore the Trans Am I'm about to get, I was thinking maybe a 4 cylinder engine (I'm not joking people
I will be the first to admit, I know NOTHING about engine swaps, TBI, TPI, carb, or anything like that. So I'm wondering if maybe a newer ecotec 2.2 L would fit?
What're the options?
I know it's a bad way to see a Trans Am, but as a young person working at a fast food place, I need as many miles to my gallon as I can get
Not only that, isn't a 305 only 145 horsepower anyways?
)I will be the first to admit, I know NOTHING about engine swaps, TBI, TPI, carb, or anything like that. So I'm wondering if maybe a newer ecotec 2.2 L would fit?
Transmission: 4L80E/4L80E
Then drive the Impala.
Some LG4's were 155 HP, some 165. L69's were 190 HP. LO3's 170. LB9's 190-230 HP.
LO3's and LB9's get very decent mileage when properly maintained.
For what a 2.2 Ecotec would cost you, you could buy a couple of mopeds.
How much gas can you buy for what it would cost you to buy and install a more "efficient" engine?
Car: 95 Camaro Z28
Axle/Gears: 3.23s
I'm reading a lot of threads, and it seems expensive to make your car NOT a gas guzzler. It just seems complicated to have a 305 running correctly, I could be wrong though?
Which 305 do you have? Year, model, etc.
A couple of hundred bucks for a complete tune-up and fluids & filters change is a lot less than several hundred to thousands of dollars for an engine change, and you'll probably have to spend the couple hundred for complete tune-up items and fluids for the new engine, anyway.
What's complicated to one is simple to another. What's economy to one is guzzling to another. It's all in the perspective. I remember gasping over $1.129 a gallon regular in 1986 when I was making a third of what I am now. Is gas more expensive now at $2.459, or was it more expensive then?
Car: 95 Camaro Z28
Axle/Gears: 3.23s
I know I want a Trans-Am, and I want it right now! This friday I'm going to buy the car.
I believe it's TPI, I could be wrong. And I have no idea what the engine's current condition is, it could need a rebuild for all I know.
TPI can sip gas if you keep your foot out of it.
Complete tune-up (plugs, wires, cap, rotor, O2 sensor, timing set properly), clean fuel system, fresh fluids (engine oil, transmission fluid, gear lube - preferably good synthetics all), clean air filter - it will do well with fuel and for a good, long life.
Originally posted by Epro
I haven't even bought the car yet
That will give you some money towards your engine swap! Thread
theshackle
Mar 5, 2017 06:37 PM
