sounds different?
Old Aug 25, 2005 | 12:34 AM
camaro25thrs's Avatar
Car: 87 iroc
sounds different?
I just redid the intake man. gasket and now the car sounds a lot louder and sounds like it has like a hot cam or something. The engine us just a stock lo3 tbi. Could it be the timing? I might move the dist. time a little
Old Aug 25, 2005 | 12:40 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Timing, a vacuum hose you forgot to plug back in, or you plain screwed up installing the intake gaskets.
Old Aug 25, 2005 | 12:56 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I agree, check for vacuum leaks and set the timming.
Old Aug 26, 2005 | 03:40 PM
Car: 87 iroc
It was the dist. gasket. There was a oil ring around it. Sounds a lot better now, but it still mis fires a bit. Is this the timing or something?
Old Aug 26, 2005 | 04:19 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
u should check the timing as soon as it is put together, the distributer, at least mine, is touchy a little bit off and it will miss, mine is at 4* adv. and it misses once in awhile, stock timing is 0*btdc. hope this helps
Old Aug 28, 2005 | 01:54 AM
Car: 87 iroc
How do u guys get the dist. gasket to work? Cause i use the one in the kit and it still leaves a oil ring around it. Should i rtv it? or should i tight it more?
Old Aug 28, 2005 | 03:58 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Likely a vacuum leak. Why guess? Hook up a gauge and see.
Old Aug 28, 2005 | 01:39 PM
Car: 87 iroc
I know its a vacuum leak, what am going to hook the guage up to, and y is it? Also I went to white hen today and i stop and when i came out and tried to started again it won't start. How to i do timing? Do i need to disconnect something?
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
