Custom Ram Air completed.
Old Oct 18, 2001 | 02:32 PM
BahamutRS's Avatar
I don't know if anyone remembers, but I decided to go ahead and make a high beam delete ram air setup for my Camaro. Until I get my hands on a L69 dual snorkel air cleaner setup, the single snorkel one that came with the L03 is going to have to suffice. I removed that heat plate thing inside the snorkel, used AC ducting and routed the pipe to the driver's side high beam (which I don't use, since I have high wattage xenon low beams). I kind of..ehh.. "cut" the high beam casing, gutted it basically, and routed the ducting to it. Using heavy duty tape I put a fine screen over the gutted casting (can't see it, looks awesome) and voila, ram air. I have to take pictures and scan them at my friend's house...so you can see it. Looks cool, I think...would be better with two snorkels, but I have enough materials left over so I'll look for one...
On to performance....
DAMN! From open element to this it's like NIGHT AND DAY! There was a DEFINITE seat of the pants difference....I gotta say, this is AWESOME. I wouldn't be surprised if I cut 2, maybe 3 tenths off my ET with this...once I hit 50 MPH the pull was incredible. Bah, anyways, you should all try this...it's not that hard.
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot), Dynomax cat-back exhaust, Hedman headers, no cat, custom high beam delete ram air w/ K & N, MSD 6A ignition, MSD 8.5mm plug wires, LT1 camshaft
Soon to be installed:
Edelbrock Perfomer TBI intake, B & M 2200 RPM stall torque converter, Trans Go shift kit, World Products Torquer heads, Ed Wright Fast Chip
Audio
Sony Xplod CDX-M610 head unit, Pioneer 2-way 4x6 front speakers, Pioneer 3-way 6x9 rear speakers, 12 inch Pioneer VCCS PRO subwoofer, QLogic sealed box, Kicker ZR360 amplifier, Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay, A-pillar gauges (Phantom oil pressure, Air/Fuel), 180* thermostat, Window Tint, chrome valve covers, xenon headlights
Old Oct 18, 2001 | 04:08 PM
Undrtkr25's Avatar
I WANT PICS!!!!!!!!!!!!!!!!!!
'89 Chevy Camaro
305 TBI
COMPLETELY stock
Old Oct 18, 2001 | 04:53 PM
92Camaro305TBI's Avatar
me too..
I was about to do this... But then I figured I would get a bigger hood
Old Oct 18, 2001 | 08:11 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
man that makes me wish i didnt have a trans am!!....i woudlnt b able to do that
weeeeeakk
oh well....anyways..i wanna see pics too!!
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
Old Oct 18, 2001 | 08:34 PM
DM91RS's Avatar
Car: 91 RS
FYI The breather from a caprice cop car has a 1" taller lid and filter with a 4" hose connection that will work well with the various automotive hoses. You can also find these type of breathers on various pickups and older chevys. I have tried 1 and 2 hoses and can tell no differance with only one even with a 350. On a 305 you don't need 2 no matter what came on the L69. Look under the hood of a newer LT1 or Ls1. Only 1 3.5 to 4" hose feeding it. But two will not hurt any thing, just extra clutter.
91 RS 5.0 TBI....LT4 cam....Edelbrock headers....3"Dynomax exhaust....5spd.... 3.08.....Ultimate tbi....afpr...ZR 255-50's...Koni's
Old Oct 18, 2001 | 09:16 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Just curions, couldn't you wire a high/low beam single headlight in the one spot? I'm not sure if anyone makes a high/low single headlight that size but it would be great.
I think a good looking screen in the old opening is the key to good looks.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
87iroctheo
Dec 4, 2016 11:47 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
bryan623
Aug 10, 2015 11:33 AM
