White smoke, but not losing liquids
Old Aug 28, 2005 | 01:01 PM
Sinisterdrummer's Avatar
Car: 1991 Firebird Hatchback
Engine: v8 305
Transmission: Automatic
I have a 91' 305 v8 firebird, and when i rev it it smokes like a motha ****a, then the exaust starts leaking water (the smoke is white)... but im not losing engine coolant or oil, the car has been sitting for about 3 months in my driveway, i searched this quick and didnt find a good awnser, any 1 got any ideas on how to fix it?
Old Aug 28, 2005 | 01:06 PM
Engine: v8 305
also the higher i rev it, the more smoke comes out.
Old Aug 28, 2005 | 01:41 PM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Have you undone the radiator cap to see if its lost any?
Just looking at the expansion bottle is'nt always enough.
As it loses water, it can often pump a load of air into the system via the cylinders, giving the appearance of no-loss.
Old Aug 28, 2005 | 01:56 PM
Engine: v8 305
yeah i checked under the radiator cap, thats how i was able to tell if it was losing any liquids
Old Aug 28, 2005 | 02:07 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
How does it smell? Water vapor is a normal combustion byproduct.
Old Aug 28, 2005 | 02:20 PM
Engine: v8 305
I just smelt like normal exaust. =/ it stoped smoking, then i took it down the road, and it started again, not as bad as before tho.
Old Aug 28, 2005 | 07:07 PM
arnold sandoval's Avatar
Car: 86 Z28
Transmission: 700
sounds like a blown head gasket or cracked head. Have you checked for water/antifreeze in the oil. I had the same problem in my GMC, but the only way I found the water in the oil was by removing the oil filler cap and looking underneath and finding a white milky substance. Blown head gasket, was my diagnosis. Hope this helps.
Old Aug 28, 2005 | 09:27 PM
Engine: v8 305
thanks for the help every one
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
