Valve stem diameter
Old Aug 29, 2005 | 01:05 PM
82TransAM84's Avatar
Car: Pontiac Trans AM 1984
Engine: V8 305 (LG4) with E4ME carb
Transmission: TH700R4
Valve stem diameter
Hello everyone,
I have a question for you, as I didn't find an answer with the search option.
I have to change my valve stem seals on my car (Pontiac Trans AM 1984 with the stock V8 305 4bbl Rochester carbed engine, aka LG4).
So I need to choose the correct valve seals, and for that, I must know the stock size of the valve stem. I looked in my shop manual and didn't find something interesting. There are blank concerning the valve stem diameter in the "engine specifications" section of the shop manual.
I read somewhere 11/32 in is the standard stem diameter on stock Chevy V8 SB. Is that true and does it apply for my car ??
My other questions are which type of seals must I choose ?? As there are different type : positive, o-ring and umbrella.
Does it depend of the type of valves ??
And, just before the finish, which material is the best for a stock engine, except the rubber from GM ?? Viton, Teflon, Nylon ??
Thank you all for you help !!
Old Aug 29, 2005 | 07:44 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
A 3rd gen in france? cool!
I believe the 11/32", standard diameter is what you want.
I'm only replying to stir others into replying, as I don't really know a lot about this.
First of all, you're only replacing these to stop leaks? no perf upgrades at the time?
Umbrella seals are stock, I *think* you need machine work to use positive, but they work way better. As i'm tearing down some 993 heads now, I got the idea they have umbrellas, and o-rings...? maybe those cheesy little o-rings on the valves are something else...?
anyway, hopefully someone else more knowledgeable will chime in...
Old Aug 30, 2005 | 05:03 AM
ede's Avatar
ede
the positive seals work best, the o ring seals are pretty worthless, i like to use the positive seals and o ring seals both
Old Aug 30, 2005 | 05:42 AM
Yes, and it's not the only one
Yeah, I plan just to stop the blue smoke that happens sometimes.
It's not too bad but it bothers me a lot to have a smoking car.
And yes, I don't plan to do some upgrades, I try to keep my engine as stock as possible. I think the day I want to improve the performances of the engine, I will stick to a 350
So, it is possible to combine both type of seals ?? That's good to know !!
Concerning the umbrella seals, can't they block the springs if they remain stock too ?? I heard they work well but with a dual springs setup.
Thanks for your help !!
Old Aug 30, 2005 | 06:32 AM
ede's Avatar
ede
i don't like umbrella seal, but they'll work, but you can't use them and psoitive seal at same time. the umbrella and positive seals go down around the valve guide boss, the o ring goes near the top of the valve stem.
Old Aug 30, 2005 | 09:54 AM
I think I will follow your advice about the use of both positive and o-ring seals. Is there a brand and seal kit you would recommend ??
Do you think, as Sonix said, that I will have to mod something if I want to use them ??
Thanks a lot !!
Old Sep 3, 2005 | 09:37 AM
Hello,
Sorry to bother you again
I would like to know if there was a stock standard outer valve guide diameter on the 82-84 LG4 engine heads ??
I saw in my shop manual there was only one type of heads used on all the F-Body V8 engines from 82 to 85
So if someone know it, can you post it here please ??
Thanks a lot !!
Old Sep 3, 2005 | 10:35 AM
Sonix's Avatar
Car: 1982 Trans-Am
certain positive seals require milling the valve guide to fit them. I heard fel-pro's vitons are some of the only positive type that DO NOT require machining. May want to confirm this, but sounds like an easy choice...
Yea, there wasn't a lot of choices of heads from the factory, I think they're taking about the "416" castings" . If you want more info, do a search on 416 heads...
I'd think whoever would be selling you these seals would know what the valve guide OD would be... (unless this is going to be an internet order, then...)
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Fronzizzle
Feb 9, 2017 09:31 AM
PurelyPMD
May 5, 2016 04:57 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
