engine stalls and idles rough.... please help
Car: 1989 Trans Am GTA
Engine: 5.7L 600cfm carb
Transmission: 700R4 (auto)
hi, i am haveing a serious problem with my 89 Trans Am GTA (5.7L TPI). the car died, so i had the heads re-done (i was told that was the problem). after i re-assembled everything, i went to start it up and it sort of runs, but it will die if i let off the gas. also it runs really rough. ive re-set the timeing 5 times now (#1 cylindar at TDC, rotor pointing bettween #1 and #8 posts on distributor cap) and it still runs like crap. now its "possible" the rocker arms may be a little loose, and not set to zero lash, but they sound fine. ive checked almost everything i can think of and i dont know what to do. when i tryed to set the valves to zero lash acording to the books, some of the valves still were a tiny bit loose, so i re did it a few times and the same results happend so i asumed i did it correctly. if the valves are even slightly outa sync, could it screw things up that badly? could it be the fuel injectors? so far ive done everything "by the book", everything is torqued correctly too. im like outa ideas, time and money so i gota figure this out quickly. any help would be GREATLY appreciated. thanks
Car: 99 Formula
Axle/Gears: 342
Check for vacuum leaks. Maybe when putting all the stuff back together you forgot a hose somewhere.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Car: 4
Engine: 6
Transmission: 5
If it idles and cruises terrible but runs OK at WOT, chances are it's a vacuum leak; that could be a hose or a gsket such as the plenum ones. If it's rough at WOT too, it could be a plug not firing for whatever reason (bad or disconnected or damaged wire, wires crossed, etc.); or one or more bad injectors, or one bank of injectors not plugged in.
Go back and recheck everything you touched very carefully; all hoses, wires, connections, etc. You'll probably run across some little gotcha somewhere.
ICON Motorsports
ICON Motorsports
im pretty sure its not a vacume leak, the car wont even stay running if i let the gas off. ive checked, and re-checked the vacume lines countless times. ive had a vacume leak before and it made a hissing noise. right now everything air related sounds fine. i have a friend whos dad is a retired mechanic and he keeps tellin me its the valves, and that they arent adjusted properly. but i want to make sure before i start ripping apart my egr system again(to get at the passanger valve cover). it wouldnt make sense for a vacume leak to make the whole engine shake and die, but i am slowly leaning towards the injectors being the problem too..... i dont suppose a can of injector cleaner would help?
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
I had a similar problem when I got my new engine. It turned out to be a few burnt up spark plug wires. Check those and make sure they are connected good. Mine backfired sometimes too.
-Matt
1984 Camaro Z28 - Black w/ Grey int.
-GM Goodwrench 350 with Edelbrock 600 Carb, Edelbrock Preformer RPM intake, AC Delco plugs, AC Delco wires, 14" Accel filter, Homemade Cold Air Indctn., Edelbrock Chrome valve covers, breather, and Air cleaner.
-Profesionally Built Turbo-350 with Hurst shifter & B&M shift kit.
- Eagle Alloys 15" Alum. Rims surrounded by P235/60R15 BF Goodrich Radial T/A's
-Comming Soon:
3.73's, MAC Cat-Back, hollowed cat. & Paint: Navy Blue Metallic w/ Silver strips
Pics at: http://members.fbody.com/flashz28/
-Matt
-Comming Soon:
backtothe80s
Sep 5, 2015 12:39 AM
