Stud girdle set-ups
Subscribe
Aug 30, 2005 | 11:19 AM
Who is running stud girdles? Can you tell me which valve covers you are using?
I am trying to keep the stock PCV system from the factory TPI set-up and was wondering if anyone else has done the same.
Reply 0
Aug 30, 2005 | 09:08 PM
Re: Stud girdle set-ups
You will most likely need the tall covers. Just get a baffle, and grommets, and use the PCV anyway. Ive done it, and I use the Brodix valvecovers. If you must cut a hole in a set that does not have them, I believe the popular diameter hole is 1.22 inches. You can get virtually any size grommet from any auto chain store. The HELP grommets are the ones Im using.
Reply 0
Aug 30, 2005 | 09:31 PM
Centerbolt or perimeter bolt valve covers?
Just wondering, why do you want to run a girdle?
Reply 0
Aug 30, 2005 | 09:36 PM
Yea, If you are not running a solid roller cam, dont waste the money on a girdle.
Reply 0
Aug 31, 2005 | 05:58 PM
Quote:
Or a hydraulic cam with a lot of spring pressure. Takes the stress off the studs.
Reply 0
Sep 1, 2005 | 11:43 PM
I'm running girdles,but I'm way up there on the cam,(well over .650 lift),but unless you really feel you've got valvetrain stability issues,don't bother.They are a pain in the A##!.If your up there on lift,but not just stupid,upgrade to larger studs.
Reply 0
Dec 28, 2006 | 11:45 PM
Why are they a pain in the rump? I have a big cam too and a co-worker says I need stud girdles or the studs will break. Is there a way around this?
Reply 0
Dec 29, 2006 | 07:19 PM
Quote: Is there a way around this?
Put in a smaller cam. You could also install 7/16" studs designed for a SBC and upgrade the rockers to SBC rockers for the 7/16" stud. BBC rockers and studs won't work.
I run stud girdles in my BBC. The girdle helps keep the rocker studs straight. My valve springs have around 200 psi closed and over 600 psi open. That puts a lot of stress on the rocker stud especially when I spin the engine to 7000 rpm. My BBC also uses 7/16" studs.
The rocker nut is replaced with a special longer one that the girdle clamps around. You need tall rocker covers to use a girdle since they won't fit under a stock height cover.
They're a pain because first of all you need enough room to run a tall rocker cover and not all cars can do that. They're also a pain if you're adjusting valves a lot. The girdle needs to be loosened off or removed before the rockers can be adjusted.
Reply 0
Subscribe
