I have $1000 to spend...
Car: 1991 Trans Am
Transmission: 4L60
...my wife says so!! I'm looking for ideas on how to spend it based on my sig below. Now, keep in mind, this is probably the last time I'll ever have this kind of money, so I can't mod based on future mods. I have to base everything on what I can get NOW. Understand? Ok, I'm going to throw my ideas out there for comments, so fire away with your thoughts. My thoughts...
Plan A:
Edelbrock TES headers with JET HOT
Edelbrock TPI base
Holley AFPR
Plan B:
SLP 1 3/4" uncoated headers
Edelbrock TPI base
Holley AFPR
Plan C:
Edelbrock TPI base
AS&M Runners
Holley AFPR
Plan D:
S/R Torquer heads
$200 Camshaft
Which of these setups will net me the most power? Keep in mind I don't have headers. If you don't agree with the above, what would you change? Feel free to suggest new setups as I could be missing something. Thank you all for your time. I really appreciate it and please hurry...I'm excited!
Fred
91 TA 5.7 TPI Automatic.
w/WS6 and 3.23 rear.
K&N Cone Air Filter (at the end of the plastic tube),Hypertech Coil, Moroso Blue Max Wires, Bosch Platinum plugs,JET 180*fan switch, JET air foil, Dual cats with Flowmaster 3" exhaust, GM Performance PROM, Complete PST components on front suspension, Spohn LCAs/Panhard bar.
My car only uses Mobil 1 transmission fluid, oil, and differential fluid.
Plan A:
Edelbrock TPI base
Holley AFPR
Plan B:
Edelbrock TPI base
Holley AFPR
Plan C:
Edelbrock TPI base
AS&M Runners
Holley AFPR
Plan D:
S/R Torquer heads
$200 Camshaft
Fred
Car: 99 Formula
Axle/Gears: 342
Go with a or b. I don't think you will get the best of power out of C with out headers.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Car: 87 IROC-Z28
Engine: 377ci, Brodix Heads, Solid Roller c
Transmission: 700-R4 w/ Yank ST3500 Converter
1. Dremel and porting bits $100. Port your base plate, plenum and touch up the heads. Follow this www.sa-motorsports.com/diyport.htm
2. SLP 1 3/4" Headers $430 at summit after 10% off
3. Comp Cams Xtreme Energy 218/224 112 ls camshaft and springs $350 plus gaskets, lube etc
4. Subframe connectors.
5. Time and patience
This is about all I was going to do with my old motor before I decided to go crazy in my quest for speed.
87 IROC-Z
Minirammed Solid Roller 377
87 IROC-Z
I agree with Mark, go with A or B, those are your best bet! Just a suggestion, you could consider getting a set of Trick Flow heads, they are a little less than a $1000, maybe enough would be left to buy that Holley AFPR.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
I would have to disagree with you guys, if I had 1000 to spend on a somewhat stock car, I would go with D. Headers and intake manifold are not that big of a deal, I think heads and cam would be the most fun to change of all of those things. If you're only going to get to do it once, I would do heads and cam. You can always port your intake later, supplies are cheap. AFPRs are cheap too. Headers..well heads/cam would be more beneficial. Just my opinion.
Car: 1991 Trans Am
Transmission: 4L60
I'm leaning toward this. What would the following do for my horsepower and torque? I plan to set the AFPR around 50 psi. Is this cool for stock injectors? With the 10% at Summit, I don't think I could be anymore efficient and effective at spending the grand.
Anyway...
Edelbrock base (EDL-3860) 320.00
JET AFPR (JET-61501) 72.00
TPIS TPI Gasket Set (shipped) 25.00?
SLP Headers (SUM-SLP30002) 432.00
SLP install kit (SUM-SLP30024) 58.00
MSD Plug Wires (MSD-31229) 60.00
Stage 8 Bolts (STG-8911) 29.00
Handling (Summit) 7.00
Total $1,003.00
Thanks again for past and present input.
Anyway...Edelbrock base (EDL-3860) 320.00
Total $1,003.00
Car: 1991 Trans Am
Transmission: 4L60
Sorry about all the posts, but I'm also going to port my plenum when I'm doing all this. Can I get a rear wheel hp estimate for all the above mods, this mod, and my sig mod? Thanks...
Fred
Fred
I think that the porting and the base is good, but you still will only flow as much as your stock heads allow. You could always port your stock intake and spend that 300 bucks on a cam and some roller tipped rockers or something.
Will your wife be okay with that extra 3 bucks?
Car: 4
Engine: 6
Transmission: 5
My advice would be headers and camshaft. Those are the first 2 choke points on these cars, so in order to get the biggest bang for the buck, I'd start there. If you have any money left over (as you should) I'd suggest rear suspension mods, like LCA lowering brackets ($60-$75 plus installation) and LCAs ($100 up).
ICON Motorsports
ICON Motorsports
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I agree on the headers and cam. If the car is parked for the winter, this is a perfect time to do some porting on the base manifold. Port the plenum also. If you feel comfortable with porting, touch the heads also. With TPI, the air/fuel mixture is only introduced at the very begining of the head port. B/c of the fuel psi, it will be easier to polish the intake tract, and the exhaust, and not have to worry so much about turbulence. Pocket porting would help too. Just an idea.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust, Dynomax Bullet Mufflers, T&R Motorsports custom air intake, Bald tires
Joshua Johnston
1991 Z-28
Car: 1991 Trans Am
Transmission: 4L60
All excellent points being made. I'm really starting to buy into the cam idea instead of the intake. Now, someone suggest a cam for a stock long block. I want one that's pretty hot, but I don't like a lope. This is my daily driver even in what little winter North Texas has. Thanks...
Fred
Fred
Car: 99 Formula
Axle/Gears: 342
Definately go with headers and cam. But don't forget to add money in for a timing chain.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Car: 1991 Trans Am
Transmission: 4L60
I can get a 3 angle valve job done locally for $60. Since I don't have the testicular fortitude to touch it myself, will this help a good cam flow pretty good?
get the three angle job done, port the plenium and baseplate, and get a new cam. then you will have enough money to buy some SLP headers. To me, this is the best option.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
'86 IROC 5-speed
305 LG4
'95 3.23 rearend
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
HEADSHEADS, cam, cheap headers, and something to make the computer like it(custom chip/good friends with chip burners) It might be a little over $1000 with all the little things gaskets, timing chain, etc. Some sort of headers is a given. HEADS and cam will make the biggest difference after that. Don't let these guys talk you into wasting you money on intake pieces. Spend $1200 and be done running 13s. Ask some people how much the paid and how much they gained in ET/MPH. I gained .9 sec and 6mph for ~$500(headers/chip/cheap stuff) and plan to gain another .5sec and 5mph with the next $700.
Car: 1991 Trans Am
Transmission: 4L60
Would a ZZ4 cam or an LT4 Hot Cam work on stock L98 heads either aluminum or iron?
How about a set of aluminum L98 heads with a ZZ4 or Hot Cam with a set of Edelbrock TES? Would this kick my *** down the road pretty good?
Engine: LS7
the LT4 hot cam is probably too much cam for the TPI induction(doesn't create the right powerband to go with the TPI)Hot cam probably wants to make power in the 5500+ range while the TPI stock or not, is only good for ~5200rpms for peak HP, most likely peak hp will be lower than that as well. Just saying in general TPIs aren't going to make usable power above ~5400rpms so look for a cam with a max operating range below 5500. That cam was designed to go into a short runner intake like the mini-ram/LT1 style. It sounds like that $1000 to spend is burning a hole in your pocket, if so, I'd say force yourself to read and learn for at least 2 more weeks before you decide on what to spend it on.
