Starting problems
Old Sep 2, 2005 | 03:16 PM
l98-tpi-guy's Avatar
Car: 1989 IROC-Z
Engine: 5.7L TPI
Starting problems
Recently I've been having problems with my car starting. I don't drive it that much (maybe once a week). It starts fine and drives fine when it has been sitting for a while. If I take it out and drive it for a while and then shut it down, it won't start back up. I have full power to everything (lights, radio, gauges are all working). I turn the key and nothing happens. I leave it sit overnight and it starts right up...
Old Sep 2, 2005 | 03:19 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Does your car have VATS?
Old Sep 2, 2005 | 03:23 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Do a search for "heat soak" and one for "ignition module."
See if either/or desctribe your predicament.
Old Sep 2, 2005 | 03:30 PM
Car: 1989 IROC-Z
Engine: 5.7L TPI
Vehicle Anti Theft System? Nothing more than the factory chip embedded in the key...
Old Sep 2, 2005 | 03:41 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Sometimes that chip wears down and the car won't start because the chip doesn't make contact. That's usually an all at once episode that doesn't fix itself. I'd check for the heat soak article listed earlier. But if it makes you feel better, try your spare ignition key to see if that fixes the problem.
Old Sep 2, 2005 | 03:52 PM
Car: 1989 IROC-Z
Engine: 5.7L TPI
Doing some searches for heat soak and ignition module led me to some possible causes:
1. Starter (heat soak)
2. Ignition module
3. Injectors (but the car runs fine, it just won't start when hot)
Any other possibilities???
My first thought was the starter, until it started right up after sitting all night...
Old Sep 2, 2005 | 03:53 PM
Car: 1989 IROC-Z
Engine: 5.7L TPI
I definitely will rule out the key before I start dismantling things... I agree, it sounds like heat soak.
Old Sep 2, 2005 | 04:32 PM
Car: 1989 Camaro
Let us know how it goes.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
