Starter wont turnover but has power?
Old Sep 2, 2005 | 07:03 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
This is the problem. The old starter seem to be dead, So I put the new starter in today.And guess what, it did the same thing which was nothing. I took the new starter back out I figured maybe I got another bad starter. I went over to the part store, they did a test check and it worked fine. So I went back home, put the starter back in and again nothing, I checked to see if I had power going to the starter and I did have power. Anyone know what else to look for? Its a 1988 formula 350 TPI with chip in key automatic tranny.
Old Sep 2, 2005 | 07:37 PM
Vader's Avatar
Does the starter solenoid even click?
Old Sep 3, 2005 | 12:23 AM
Anvil's Avatar
When you say you have power to the starter, does that mean you have power at the starter end of the cable or at the battery end of the cable?You need power at the starter end. It might be a bad cable. I replace the cable when I replace the starter.
Old Sep 3, 2005 | 09:29 AM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
No, it doesn't do nothing at all.I have power at the stater. i checked it with a test light at the main stud on the solenoid.
Before all this happened the car started up,i ran it for about 10 mins shut it down then went to start it up again and that all she wrote ??????????So 2 starters late and i still have the same problem?
Old Sep 3, 2005 | 12:25 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Get your spare key out and try to start the car. Your original chip might have worn down and is now causing the V.A.T.S. to stop you from being able to start the car. Same thing happened to me and it really p***ed me off.
Old Sep 3, 2005 | 03:33 PM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
The purple wire going to the solenoid should get power when you turn the key to the start position. Did you check for that?
Old Sep 3, 2005 | 04:52 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
I have no power going to the purple wire.I tested it for POS and NEG,when i put the test light to it on the NEG side i get nothing,But when i put the test light on it with a POS side i get a light?
Old Sep 3, 2005 | 05:02 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
OK, I jumped the starter. I jumped the side of the starter were the purple wire goes and the car will start. So can i eliminate the VATS being the problem????
Old Sep 3, 2005 | 05:17 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Does it start in neutral?
Old Sep 3, 2005 | 08:21 PM
Car: 1989 Camaro
Stekman suggested trying to start it in neutral. I think he might be heading in the direction of a neutral start switch that is faulty or out of adjustment. This is definately a possibility you should look into. Another possibility is that the ignition switch has gave up the ghost. I would investigate both of these possibilities further. Post back and let us know what's going on. I think TPIgirl was heading in the direction of the ignition module too. Both are very helpful posts. I just kinda condensed them, but I wanted to make sure credit also went to the people who suggested it first.
Old Sep 3, 2005 | 09:21 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Did it start, or just turn over? If it just turned over, you cannot eliminate VATs...Vats disables the start enable relay and injectors, IIRC.
Old Sep 3, 2005 | 09:45 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
doesn't that purple wire have a fusable link? that could be bad. that was were i thought tpigirl was going with it.
Old Sep 3, 2005 | 11:23 PM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
The purple should be from the ignition switch under the dash.
I think if a fusable link was out then you'd lose power to some other things as well.
Maybe the VATS does disable the purple wire at the switch ?
Anyway, I know that when you turn the key to start the purple wire gets 12 volts normally.
Old Sep 3, 2005 | 11:27 PM
87zjeff's Avatar
i don't know if it is the same exact problem or not. i had a fusable link go out a few years ago. when it did, the starter wouldn't do anything but i still had lights and everything else(guage lights,stereo, etc.)
Old Sep 4, 2005 | 01:06 AM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
It started and ran fine,I shut it down with the key.I also tried to start the car in neutral it i wont start.The only way i can get the car to run is if i jump the starter.
Old Sep 4, 2005 | 03:42 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Either the VATS isn't grounding the starter enable relay, or there's no power to the relay's coil. The VATS is enabling the ECM, if it wasn't the injectors wouldn't fire.
Quick test, ground relay, turn key, if it starts the VATS module is faulty.
Old Sep 4, 2005 | 08:40 AM
Car: 1989 Camaro
Rgarcia makes a good point that didn't occur to me. The fusible link suggestion is also a good point. I'd follow the purple wire back and see if you lose power anywhere. The fusible link is a possibility, but so is the fact that the wire could just be frayed. Just for clarification, when I said Igntion Module, I wasn't talking about the one in the Distributor. I think there's one under the dash, but I might be remembering it from my Mustang. I didn't see one on the Haynes wiring diagram. If somebody with a less faulty memory than my own wants to set the record straight, feel free.
Old Sep 4, 2005 | 09:04 AM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
Which relay is it,were is it located?The book i have dont really help all that well.Thanks for helping out
Old Sep 4, 2005 | 09:33 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Hmmn, just re-read original post, did Pontiac start using VATs in '88?
Anyways, starter enable relay in my '89 is behind the driverside kick panel. Hanyes/Chiltons should show it in the electrical diagram.
Old Sep 4, 2005 | 09:42 AM
Car: 1989 Camaro
Front seating area, on the driver's side, under the dash, mounted just above kick panel just like 8mike9 suggested.
Old Sep 4, 2005 | 09:43 AM
Car: 1989 Camaro
Did you already try using your spare ignition key to try to start the car?
Old Sep 4, 2005 | 10:08 AM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
The guy that i bought the car from didnt have the spare key?
Is the relay part of the fues block or is it set off the side of the fuse block?
Old Sep 4, 2005 | 10:11 AM
87zjeff's Avatar
ok my car,there is an ignition switch on the steering column that is actuated by a shaft that comes from the key cylinder area. the purple wire goes from this to the starter i believe.
Old Sep 4, 2005 | 10:12 AM
Vader's Avatar
When you get to the starter enable realy, you will also be near the ignition switch. A failing ignition switch can also cause your problem. A steering column that is worn, loose, and has sloppy linkage rods to the switch can also cause the proiblem. Does the system go to bulb test mode when you try to start? Does the temperature guage sweep to full scale?
Have you tried starting in neutral as suggested?
If you suspect the switch, have an assistant operate the ignition key while you check the voltage at the switch.
Old Sep 4, 2005 | 10:31 AM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
I jumped the relay and the car truns over.Si i guess the relay is bad?
Old Sep 4, 2005 | 03:37 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I don't have a schematic in front of me, but if the relay is getting power, and not energizing, yes, it's bad. Unsure if if power is appplied to energize, or ground is applied to energize...look a schematic over to verify.
Old Sep 4, 2005 | 03:44 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
I want to thank all the guys and girls that helped me out.You are all great people, Thank you! Ill let you all know how i make out when i get the new relay in.I would of had it in today, but its a dealer part the part store guy told me.Thanks again
Old Sep 4, 2005 | 09:59 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Can you describe step by step how you jumped the relay?
This will help me determine if the relay is bad, or if you still might have a bad VATS module which, is located in the dash behind the HVAC system.
8Mike9 is correct:
Regardless of which circuit is faulty, once it's determined that the wiring, and starter relay are good, that leaves the VATS module.
If you permanently enable the start relay, the injector enable circuit will still protect your car, this circuit is more difficult to circumvent than the starter relay.
Old Sep 5, 2005 | 10:40 AM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
I jumped the first contact on the hardness to each contacted on the heardness on the way down. till i got to the last contact point.Thats when It started rt up.??
Old Sep 6, 2005 | 01:13 PM
pat202's Avatar
Car: 92 firebird,2000 firebird
Engine: v6,V6
hello all! i am having the same problem with my 92 firebird but the difference is that when i try to start it and it wont if i wait for 10 -15 minutes it will start plus it will go months some times before it does it again i get power to all my gauges, radio and head lights
i have changed the battery and starter anyone have an idea what it maybe causing this ????
Caspar
Jun 19, 2016 11:19 PM
5spdcamaro
Aug 28, 2015 02:12 AM
L98GTA87
Aug 25, 2015 02:23 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Accerrito22
Aug 23, 2015 07:22 PM
