ENGING JUST CRANKS won't fire
Old Oct 17, 2001 | 09:06 AM
Tom Batts's Avatar
Old Oct 17, 2001 | 08:35 PM
GOLD85's Avatar
have u check for fuel presher and spark.
when the green flag drops the bull$hit stops
pulled the 350 to make way for the 406 wich is in the machine shop. got a comp 282S bump stick with 1.6 rockers. looking at differnt heads right now.Perfomer RPM and holley 650 DP, headers and 3 inch exhust. 3000 stall converter and a built 700r4. shotin for mid 12s next summer
Old Oct 18, 2001 | 07:07 AM
Tom Batts's Avatar
Old Oct 19, 2001 | 01:18 PM
82z's Avatar
82z
All bets are off when you have an aftermatker alarm system installed in a vehicle. I have learned to hate them so much. Anyway make sure your injectors are pulsing, and that your ignition module is receiving a signal from the pickup coil. Remember that the ecm has nothing to do with the ignition system under 600 rpm. make sure your coil is in specs and is receiving a signal. good luck
Old Oct 19, 2001 | 01:23 PM
rezinn's Avatar
That white box looks like a flasher for your turn signals. Does the fuel pump prime? Check for fuel pressure and spark, d00d
Old Oct 19, 2001 | 03:48 PM
Tom Batts's Avatar
Old Oct 23, 2001 | 08:38 PM
Tom Batts's Avatar
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
Formula_88AE
Sep 3, 2015 01:47 PM
