2nd maybe even 3rd opinions on my oil leak?
Old Sep 6, 2005 | 06:03 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Alright well my oil leak is getting worse and its about time i do something about it...
Last 3000 miles it lost 1/2 quart...few drops every night
Now its lost over 1/4 of a quart in less then 800 miles...and almost everytime i drive the car i smell burning oil which is burning on my Y pipe...
Ive asked a few board members...there is no oil on the flexplate or torque converter which leads me to beilive its not the Main Seal?
It doesnt look to be right there but from up above the tranny...
I took a few pictures so you guys can see a little better...
Valve covers are clean...so i guess my last option is the intake manifold? Thats what another member suggested to me.
From the top i can see some wet spots down below the passenger side header...
Its too hard to see exactly where its coming from...i took off the plastic distributor cover and its greasy back there doesnt look all that wet though.
Underneath it looks like its coming from above the starter and leaking off the brake lines...
The car leaks like 3 drops everytime i turn it off then its slowly after that...its got me worried now...After long trips u can see smoke from it burning on the exhaust pipe.
If it is the intake manifold how much work we talking here? I drive the car everyday to work so i need it monday-friday...
On a side not I replaced the PCV valves...and it leaks on the driver side...did i forget to do something?
Attached Thumbnails 2nd maybe even 3rd opinions on my oil leak?-intake-leak-1.jpg
Old Sep 6, 2005 | 06:05 PM
Stevo's Avatar
grr...
Attached Thumbnails 2nd maybe even 3rd opinions on my oil leak?-intake-leak-2.jpg
Old Sep 6, 2005 | 06:49 PM
Scheister's Avatar
Car: 85 IROC
mine looks the same, but mine is leaking from the back of the valve covers. removing the intake manifold isnt too hard and can easily done in a day if you dont strip and of the torx bolts, although i did have a heck of a time getting at some of the bottom runner torx bolts.
Old Sep 6, 2005 | 07:06 PM
Stevo's Avatar
Well my valve covers are clean from what i can tell...they dont appear to be leaking oil unless its under the gasket from what i cant see...
i gotta fix this leak...its getting a lot worse and the smell is really bad
Old Sep 6, 2005 | 09:47 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Adding some UV dye to the oil next time you change it would help pinpoint the source of the leak.
Judging from the amount on the rear of the oil pan, it could be the rear main seal, it could also very well be the rear part of the oil pan gasket is shotty.
I know you said the flexplate looks clean, but what about the engine side of it?
Old Sep 6, 2005 | 10:13 PM
corky9491's Avatar
Car: 83 Berlinetta
Engine: 355
Transmission: TH350
I would check the oil pressure sender that is behind the distributor.
Old Sep 6, 2005 | 11:06 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Old Sep 6, 2005 | 11:39 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Except he has a 92, so his sender and switch are combined into one and on the driver side, just above the oil filter.
Old Sep 7, 2005 | 07:02 AM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
run a clean rag at the back of the intake and see if it's got fresh oil on it.
Old Sep 7, 2005 | 04:50 PM
Stevo's Avatar
im gonna go check everything you guys mentioned and give u some results
Old Sep 7, 2005 | 09:48 PM
Stevo's Avatar
Behind the flexplate towards the engine is not wet...all up in there between it does not appear to have any oil on it...
I treid to run a rag back there but i couldnt get to anything other then what i could see...
I do see some fresh oil right behind the passenger side header....like right of the distributor but down some...What could be back there...
This is really a pain i need to find this oil leak, id like to not have to take half the engine apart to find it either...
anymore suggestions guys? anyone have or had an oil leak like mine in the past?
Would you guys suggest cleaning it all down with brake clean and what not and just watch it run for awhile? I kinda tried that a few months ago...
I mean its really hard to pin point it
Old Sep 7, 2005 | 09:55 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Like rear china wall area?
Old Sep 7, 2005 | 10:10 PM
Stevo's Avatar
dont really know where that is? id take a picture of the visable new oil coming out but the cameras flash seems to make it shadow there...maybe i could make a paint and point arrows...
Old Sep 7, 2005 | 10:14 PM
Stevo's Avatar
alright here we go...example of what i was just talking about:
Attached Thumbnails 2nd maybe even 3rd opinions on my oil leak?-intake-leak-3.jpg
Old Sep 8, 2005 | 07:15 AM
Scheister's Avatar
Car: 85 IROC
is there oil back there above the tranny? if so i think it could only be either valve covers of intake manifold
Old Sep 8, 2005 | 08:16 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'd run my finger around the valve cover bottom and see if theres any oil. Thats where I had a leak and I had similar oil drips.
Old Sep 8, 2005 | 09:39 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I'm going to laugh if I'm right, and we both made the same mistake...
But where is your dipstick located? Right above the starter, correct? Now answer me this... Is the dipstick tube inserted into the hole correctly?
Old Sep 8, 2005 | 02:18 PM
Stevo's Avatar
alright under the valve cover not wet at all....
and dip stick ive never messed with and its not leaking...
Im gonna go once again jack up the car put it on stands spray the **** outta it with brake clean and watch it run...Ill tell you guys how it goes...i dont know if theres really anymore to tell.
After all this i guess im pulling off the upper intake manifold and the runners...not much else left to do.
Im curious to what a shop would being do if i brought the car to them...which i really dont wanna do.
Old Sep 17, 2005 | 08:55 PM
95blue350's Avatar
Car: 95 C1500 Ext. cab
Engine: 355 TPI running on the TBI ecm
Axle/Gears: 3.73 GM 10-bolt
I had the same type of oil leak looks just like the picture, mine was leaking from the distributor gasket.
Old Sep 17, 2005 | 09:22 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
i have an oil leak where the drips are coming from look eactly like yours, However i found that my Oil pan gasket blew, have you checked your gasket?
Old Sep 17, 2005 | 10:24 PM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
Judging by where the oil is dripping from it is either coming from the valve cover, back side of the intake, distributor seal, or the oil pan.
The most likely is the intake. They are notorious for leaking back there. With the age and mileage on your car, I'd be willing to put money on it.
If you take your time I'd plan on 6hrs start to finish. Just beware you will need to verify/set the timing since the distributor has to come out. However if your going to do it yourself... its a good time to port the intake
Although you could spend the $15 and do the valve cover gaskets. It definately wouldnt hurt especially if they are original.
Old Sep 17, 2005 | 10:26 PM
TKO500's Avatar
So what is in the whole where the old style sender was? My block is a 92 installed in an 87 but it had the whole there. If there is a plug in it I suppose it could be leaking. Kinda a long shot though.
I'm putting money on the intake!
Old Dec 28, 2005 | 11:37 AM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I have been doing alot of reading because I have a very similar oil leak. The engine has 2600 miles on the rebuild and is a 1971 350 block. Here is the question I have before I start checking and tearing everything apart, should the oil dip stick tube move around freely or should it be tight. Lat time I checked the oil the tube seemed really loose.
Old Dec 28, 2005 | 04:18 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Have you looked inside the dizzy cap? See if there's oil there - might be the dizzy leaking on inside instead of outside - mine did that. I'm betting dizzy, or intake mani.
I've done my intake mani gaskets 3 times, and mine still leaks. Everyone has different method, some say use the rubber on the china walls, some say don't. Some say use RTV with the rubber, some say only RTV, some say only rubber. Some say let the RTV dry for an hour, some say seal it wet, some say let RTV dry for 4 or more hours. I'll just keep doing mine until it seals I guess lol.
Old Dec 28, 2005 | 04:59 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Well that is a great possibility,
I have been doing alot of reading and running out and checking. I put my hand on the block between the distributor and firewall and there sure as chit was oil back there. Now if it was a rear main seal I am guessing the oil couldn't possibly travel that high could it?
tricky1
Aug 23, 2015 01:17 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
drathaar907
Aug 6, 2015 04:20 PM
