What to use on threads for water pump?
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'm putting all the accesories on my car then starting up the new engine for a first time. I'm just curious what to use to seal the threads for the water pump.
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
Are you talking about the water outlets (heater hose connections) ? If so, all I ever use is regular teflon tape. If you are talking about the bolts that hold the pump to the block, I use nothing. Never had a leak, ever.
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Never used anything, except a bit of copperslip on the bolts to ease getting them out in future.
You dont need to "seal" the bolts as such.
Car: 86 T/A
Engine: HSR 355
Originally posted by Engineboy
Don't forget to put a thread sealant, not silicon, on the bolt threads. (I use Loktite PST with teflon), the bolts go through to water passages.
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
So whats beter the copper sealant or the locktite? If you use locktite, that just keeps the threads from coming loose right? Does'nt seal anything.... Doesn't need to in this application right?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Originally posted by firebirdjosh
That was posted about 3 years ago, I just saw it and panicked. OK, thanks guys!
Engine: LS3
fewwww..... ok, thats all i needed to hear.
(the thing about the V8, and water)
Thx for clearing that up
Engine: 302
Axle/Gears: 3:73:1
Yeh sorry, i wasnt very clear, its a grease, [copper based] thats an anti-seize compound.
Usually available in tubs or spray can.
And the aluminium variety is good too, you can get some that can be used on exhaust bolts as its vht [very high temperature] and can resist the temperatures of headers.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Originally posted by Russ-So Cal
Sealant is not needed on the v8, the bolts don't go through to water.
LocTite offers a lot of chemicals in their product line. It extends well beyond the anerobic thread lockers for which they became famous. The LocTite PST is a thread sealant, not a thread locker.
FWIW, Permatex/Loctite anti-seize (133K) is primarily a nickel-based compound, not aluminum. It contains a variety of other metals, as well as oil and soluble wax. They also have other formulas of anti-seize, including a high nickel variety that is very dark gray, and not the popular silver/aluminum color of the "regular" anti seize.
Yes, you don't need to apply thread sealant to the water pump bolts. You also don't need to torque head bolts. You don't need to inflate tires if you choose not to. It's all up to you. If you want to see which ones are drilled through to the cooling passages, don't use sealant. They'll become apparent soon enough.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
