highway cruiser SBC
Old Sep 12, 2005 | 09:51 PM
black85iroc's Avatar
Car: 1985 camaro IROC-Z
Engine: Lg-4 305
Transmission: t-5 5 speed
highway cruiser SBC
so i want to make my car more of a highway cruiser, but i don't know how to look into making a higher RPM motor with decent power. what bottom end should i start with? just a basic 4bolt 350? maybe destroke a motor so it revs higher/faster (like a 400 block with a 350 crank, or a 350 block with some smaller crank)? also, besides cam and intake, what should i look at to make power in the upper RPM range? what do i need to look at when choosing a carb for this type of application? unlike when i built my stupid 305 i acctually want to do the research first, so give me your thoughts. also i would think about doing fuel injection if it really makes that much of a difference.
Old Sep 12, 2005 | 09:57 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I don't get it what do you want to do? First your talking about a cruiser and then your talking about high rpm. Make up your mind, those are opposites.
Old Sep 12, 2005 | 11:09 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Maybe he wants to go flying down the hiway @ 100mph in 2nd gear??
Yes, what exactly do you plan on doing with it? What RPM range are you at while at "cruising" speed?
Old Sep 12, 2005 | 11:11 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
we need more info man, can't help you much at all right now
Old Sep 13, 2005 | 12:24 PM
montesa311's Avatar
Car: 83-84 camaro, 95 formula firehawk
Engine: 305, 305ho, 350tpi, 350 lt1, 383lt1
Transmission: 700r4, t-5, t56, m6
Axle/Gears: 3:90, 4:10, 3:50, and more
lol, my brother drives like that..... its scary when you have to remind someone to shift...
Old Sep 13, 2005 | 12:26 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Next thing ya know youll be reminding him to turn!
So black, are you ever coming back to your thread?
Old Sep 13, 2005 | 12:32 PM
Engine: Lg-4 305
i only made this thread last night. alright scratch the idea of a highway "cruiser" what i meant by that i just meant if i down shift while driving on the highway to pass/ keep up with other cars/whatever having the power down low isnt going to do me any good. i want the power from like 3000-6000 or so, right now after about 4,000 RPM or so my car doesnt really pull.
Old Sep 13, 2005 | 12:39 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Well depending on the setup pretty much any 350 makes its max power 4500-6000RPM.
Solution, Dont downshift!
What do you have already and what do you plan on spending?
Old Sep 13, 2005 | 12:58 PM
montesa311's Avatar
lol, its funny you say that about reminding him to turn.........theres a story there for another day, another thread.. as for a good motor for cruzing without having to shift.... swap in a newer 350 and be done! cheap, farily easy, and good gas milage, if your instant on building a good cruzing motor, there are some good books out there like Max performance chevy by david vizard, smallblock chevrolet by a pair of larry's, how to build horse power again by david vizard... all of those are by the same publisher... a good but basic set... if your more into tech manuels let me know i have some incredibly dry reading and dry humor, but an absolute for the "at home engine builder"
Old Sep 13, 2005 | 05:57 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Get a cam with duration @.050 in the 24? on the intake and 25? on the exhaust.
RedLeader289
May 28, 2019 01:47 PM
gixxer92
May 18, 2017 11:20 AM
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Bradsaundry
Oct 7, 2015 04:35 PM
