finding tdc and piston stop
Old Sep 14, 2005 | 10:09 PM
badazz84camaro's Avatar
I'm having a problem trying to adjust my timing pointer. I bought a proform piston stop to find tdc. With it installed, i can turn to motor over and it wont hit the piston stop. I have flat top pistons and trick flow heads. Is there anything i can do or make because i dont have time to pull the head because i have to go to the track on friday. thanks
Old Sep 14, 2005 | 10:59 PM
ttt
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Did you take the rockers off of the cylinder that the piston stop is in?
If so then then the stop isn't in far enough. The only way a piston stop can tell you where TDC is is with a degree wheel.
Old Sep 14, 2005 | 11:12 PM
rockers are off both valves and the screw in the middle is in all the way
Old Sep 15, 2005 | 07:47 AM
AlkyIROC's Avatar
Car: 87 IROC L98
and when you bar the engine over by hand the piston doesn't hit the stop?
Old Sep 15, 2005 | 01:20 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I had the same problem with my Sportsman II heads. The threaded part wasn't long enough so I got a piece of threaded rod, cut it off about an inch longer than came on my piston stop, and used it - worked fine!
Next question - if you go one way and mark the stop point, then turn the motor over the other way to the stop point, TDC should be EXACTLY the mid-point between the two marks, right? If so, my pointer is off about 4 degrees....
Old Sep 15, 2005 | 02:31 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Make your own piston stop.
You can see how here
Old Sep 15, 2005 | 03:02 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
This is kind of a rigg job way but it will work . Take a pice of wier and feed it down the # 1 tube bend acordingly . You want the wier long enoghf so you do not loose it and have a few inchs left. Take another pice of wier and make a loop that can be in a fix position atatch to head somewhere . Feed the the up down wier though the loop . Take a marker and mark the stops . Not the correct way but it get you close .
Old Sep 15, 2005 | 08:34 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Correct. That's why you should be using a degree wheel. After turning one way then the other, you calculate half way between the 2 stops. Turn the engine over until that mark is at the pointer you used for the degree wheel. Adjust the adjustable timing mark to indicate TDC. Using an adjustable timing pointer, you should be using a marked balancer or timing tape on the balancer to set your timing.
The first engine I put together years ago ran fine but I was worried about the 50+* of timing I had it set at. When I finally checked TDC I found I was actually out 8*.
Don't believe your timing marks unless you find TDC with a degree wheel first.
Old Sep 15, 2005 | 09:33 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
I've seen factory pointers off by as much as 8*. Every motor I put together now gets checked and most end up with aftermarket pointers or re-located stock pointers b/c they're off.
Old Sep 15, 2005 | 11:15 PM
vernw's Avatar
Well, since my mid-point comes out to 4*BTDC, then I guess I'm really only running 2*BTDC base timing since I set it for the "normal" 6*BTDC initial. Thanks, Folks!
Old Sep 22, 2005 | 09:58 AM
scooted45's Avatar
Car: 86 sport coupe, 89 IROC-Z
Engine: 5.7 TPI, 5.0 TPI
Transmission: T-5, T-5
Axle/Gears: drum posi 3.73, disc open 2.73
I got this one from some BMW guy:
Gut a spark plug and fit a piece of clear tubing in it
thread the plug and put the other end of the tube in a can of oil
to find TDC, turn the motor untill the oil is neither pulling or pushing
worked for me because my dampener was so rusty I couldnt see the timing mark
Old Sep 22, 2005 | 10:10 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
hmm... anyone actually find some nasty marks ontop of the piston from the piston stop? Or break a piston stop in half dropping it into the cylinder? or... strip the spark plug threads because of the pressure applied to the piston stop? I just turned the crank while whatching the pushrods to see which stroke was the fireing stroke. Worked fine, timing is perfect now with those caculations.
Old Sep 22, 2005 | 07:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Timing is like any other accuracy. thermometers, tire pressure gauges etc all have variance. Try finding 2 watches with the exact same time.
Someone builds an engine and asks what the timing should be set at. Just because one engine like 36* total timing doesn't mean it's accurate. It also doesn't mean your timing marks are accurate. Once you set the timing mark for TDC, any timing adjustments you do are as correct as you can make them.
Even different timing lights can give different readings. I've tried an advance timing light and wasn't accurate enough. Since my balancer has the degree marks on it, I just use a normal, cheap craftsman, point at marks type. The multifire ignition causes the timing to jump around at low rpms but my distributor is locked at full advance so it doesn't matter what rpm the engine is at when I check the timing. It's always the same.
Old Sep 22, 2005 | 07:51 PM
F-BIRD'88's Avatar
Some people should just stay away from cars.
You don't use the starter motor to rotate the crank to find TDC. There is no need to use excessive force to turn the crank by hand.
jklein337
Sep 19, 2018 06:23 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
db057
Sep 4, 2015 07:57 AM
86IROC112
Aug 17, 2015 07:57 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
