How to tell if this noise is a cam bearing?
Old Sep 17, 2005 | 07:51 PM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
"tick tick tick tick tick", you get the point. lol
Anyway, my engine makes a ticking noise that goes along with the engine RPM's and only really appears after the engine has warmed up a few minutes and is most evident at around like 2000+ rpm's
Using a radiator hose as a sorta stethoscope (sp), everyone thats listend to it has agreed that it most likely isnt valvetrain related because it doesnt come from either side of the engine, but more towards the middle....
Cam bearing is all I can really think of, how do I tell for sure? If it is, what am I in for? Thanks,
-Chris
Old Sep 17, 2005 | 08:13 PM
ede's Avatar
ede
since a cam spins i'll bet it's anything but a cam bearing
Old Sep 17, 2005 | 11:36 PM
what else could it be?
Old Sep 17, 2005 | 11:57 PM
sellmanb's Avatar
Car: '86 Berlinetta
Is your car CC Carb?
It could just be a loose rocker arm, or a stud pulled out causing that loose rocker arm. Could also be a lifter, though I doubt it.
Could also be pinging. You are sure it's not an exhaust leak at the header gaskets?
Old Sep 18, 2005 | 01:00 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Depending on the loudness/tone of the "tick" it could also be a bit lower, maybe a con rod.
Old Sep 18, 2005 | 05:28 AM
its non CC
Reason we dont think its valvetrain related is because it doesnt seem to come from either side of the engine specificly, but more from the middle...
anesthes
Mar 10, 2016 10:35 PM
xxx3man`
Sep 23, 2015 10:37 PM
gixxer92
Sep 1, 2015 04:32 PM
anesthes
Aug 26, 2015 01:37 PM
