removed canister & valve....what to do with open ports
Old Sep 18, 2005 | 07:56 PM
8285z28's Avatar
Car: 1982 z28
Engine: lg4
Transmission: saginaw 4 spd
today i removed these
Attached Thumbnails removed canister & valve....what to do with open ports-canister.jpg
Old Sep 18, 2005 | 07:57 PM
8285z28's Avatar
Car: 1982 z28
Engine: lg4
and this
Attached Thumbnails removed canister & valve....what to do with open ports-valve.jpg
Old Sep 18, 2005 | 07:58 PM
8285z28's Avatar
Car: 1982 z28
Engine: lg4
what do i do with the port with the pensil in it...i think its a vent , should it be left open?
Attached Thumbnails removed canister & valve....what to do with open ports-carb.jpg
Old Sep 18, 2005 | 07:59 PM
8285z28's Avatar
Car: 1982 z28
Engine: lg4
and this line returns to the tank. now its capped.......is that what i should do with it?
Attached Thumbnails removed canister & valve....what to do with open ports-line.jpg
Old Sep 18, 2005 | 09:22 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Remove pencil and cap it...
Old Sep 18, 2005 | 09:45 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Why did you remove the evap canister? Might want to uncap the line that goes to the tank. Vent it somewhere.
Old Sep 20, 2005 | 12:41 PM
ssean92's Avatar
Car: sold
sorry to hijack your post but i was going to post this same thing. the only diff is mine is fuel injected. i need the room for the aircleaner. will this cause problems with my lt1? heres why i did it.
Old Sep 20, 2005 | 01:54 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
a pencil???
holy cow I can barely breathe i'm laughing so hard here.....
good lord, that's so incredibly red-neck-ish! That's worse then my car when I bought it....
Yea, use rubber caps, pack of 10 is about $5.
If you don't use the evap canister I think your car starts to stink like gas, mine does and i'm thinking that's why....
Old Sep 20, 2005 | 05:28 PM
8285z28's Avatar
Car: 1982 z28
Engine: lg4
just for the record sonix, the pensil was put in just for the photo to show which port i was talking about........dont believe me. put a pensil in there and you will see its much smaller than the port.......
Old Sep 20, 2005 | 05:47 PM
Sonix's Avatar
Car: 1982 Trans-Am
fair enough, that just left me doubled over laughing...
mine was plugged with a sheet metal screw.... good *** that was hard to get out...
Old Sep 20, 2005 | 06:19 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
lol
sounds like something my step-brother would do, for some reason he likes those self taping screws and uses them for everything.
Just out of curiosity, was it an 88 iroc painted blue with crappy spray bombs??? if so that was my step brothers...
May that car rest in peace
Old Sep 20, 2005 | 06:21 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Why in the world would you remove that stuff from the car?
Old Sep 20, 2005 | 11:51 PM
85_TA_WS6's Avatar
Car: 1989 GTA
Engine: 350 TPI L98
I'm removing those right now from my GTA. The reason you remove those is because they are basically useless and clutter the engine bay. When the charcoal canister is new it works to absorb and recirculate fumes back through the engine, but when it gets old the charcoal inside gets saturated and it serves no purpose but to sit there and take up space and weight.
The "pencil hole" is from what I can tell..a vent. Trace the hose that was originally connected there and see. If it goes to the canister its the intake from the canister for the fumes, if it goes to the valve cover then its just a breather.
The metal line you had capped off is your gas tank vent line. Don't plug that, instead get a length of rubber hose from the hardware store and run that line down inside the fender or something, but make sure it is facing down so no moisture or crap gets in there.
When you pulled all those hoses odds are you pulled the hoses that connect to the air injection lines to the exhaust manifolds and the cat. cap those off too until you remove the metal lines completely (which would look much nicer).
The other thing you can do is to pull the air pump which will free you up some horspower. On my L98 it is just below the AC compressor but Im not sure where it is on your motor, probably the same place but on yours it would be under the alternator.
Old Sep 21, 2005 | 05:14 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
question, couldn't you run the vent straight to the throttle body where the canister originally went? or would this cause problems?
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Aug 8, 2015 07:09 PM
