My engine ODed on coolant, found the problem pics here
Old Oct 1, 2005 | 04:34 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
Has anyone seen this before? (how the gasket is streched)
I don't think I forced the gaskets like that to rip it, its odd how the hole is elongated. Right now I can only think of heat expansion causing this. They were felpro gaskets too!
Old Oct 1, 2005 | 09:38 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Stretched hell, it looks broke.
May want to check the intake, it may not be true.
Old Oct 1, 2005 | 10:50 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
that's pretty damn weird.
Test for flatness of contact surfaces with a straightedge
if they're all fine then I'd try a fresh FelPro gasket
Old Oct 1, 2005 | 11:10 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Very interesting...
I doubt it heat expansion, If everything expanded enough to rip that gasket apart you would have alot more problems.
Old Oct 1, 2005 | 11:13 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Looks like the inside of my old 305. Id say either the gasket surfaces arnt true, or it was overtorqued, causing excessive crush. It could also have been damaged during installation as well.
Old Oct 2, 2005 | 01:14 AM
CrimsonDragon's Avatar
Car: 89 IROC - 85 Z28
Engine: 350 / 305
Transmission: 700R4 / T5
Axle/Gears: Stock
Had a similiar thing happen to mine. Was thread sealant used when the manifold was installed? We surmised that with mine there wasn't and I had coolant running out the exhaust. My gaskets looked even worse when we pulled mine.
Old Oct 2, 2005 | 11:19 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Its hard to tell from the pic but are these not the type that has the metal sheet running through the middle?
Old Oct 2, 2005 | 11:22 AM
WhiteHawk's Avatar
Car: 1991 Firebird
I guess I over torqued it. I am not that big of a guy and I used a little 10mm wrench that is about 5in long. Who knows, but whatever, I wanted to upgrade the rotating assembly before a catastrophic failure and also ,I had put the engine together even though I should have sleeved a cylinder cause it had pits in the wall and now I can do that. Eh, I just wanted to blame felpro
Spyder_TheGamer
Dec 25, 2015 05:07 PM
TheExaminer
Aug 26, 2015 04:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Fronzizzle
Aug 9, 2015 01:15 PM
antares57
Aug 6, 2015 07:47 AM
