Factory non a/c look
Old Nov 5, 2001 | 04:20 PM
iroc5speed's Avatar
ok, I want to do an a/c delete because it oesn't work, I don't use it anyways, and it just gets in the way of everything, so I'm going to get heater controls and everthing from a non a/c car and I was wondering how hard it is to do the job. Taking everything out should be no problem, but what abou the new heater setup?
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Old Nov 5, 2001 | 06:36 PM
Blucamaro's Avatar
it's not very hard.Just did a 87 iroc....Cake walk
Old Nov 5, 2001 | 07:37 PM
iroc5speed's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Blucamaro:
it's not very hard.Just did a 87 iroc....Cake walk</font>
did you put new controls in though, to make it look like it only came with heat and not a/c?
Old Nov 6, 2001 | 04:15 AM
Blucamaro's Avatar
no,the regular controls worked just fine,just when you put it on A/C it will just blow like you have the vent on.other then that the heat,defroster,ect. all work.I'm going to do my 84 soon.We come across a/c delete cars often
Old Nov 6, 2001 | 06:21 AM
iroc5speed's Avatar
see I want to take the controls out and put in just heater controls. I'm sure it's not too tough but I was wondering what's imprtant to keep in mind while doing this. anhyone ever made the delete look like there wasno a/c from the factory?
Old Nov 6, 2001 | 08:50 AM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
I'm with you on this. I'd like to do it to my "track car" soon. Unfortunately I don't live near the junkyards, so I don't know how or when I'll be able to swing it. The guys selling this stuff on the classifieds here are smoking crack! They think factory non-a/c stuff is like gold or something.
I've heard that an S-10 heater-only setup will work. I have not verified this, and it may only be in reference to the firewall side of things. I'm not sure.
Please let me know what you find out and do to your car!
Clem
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
[This message has been edited by clemsparks (edited November 06, 2001).]
Old Nov 6, 2001 | 09:52 PM
iroc5speed's Avatar
I'll let you know man, though I won't have a chance to do this for quite a while yet, several months at earliest.
Old Nov 6, 2001 | 10:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I don't know how difficult it would be, but it won't be as simple as just changing the control head. The vents in non-A/C cars are cable actuated, not vacuum actuated.
Old Nov 7, 2001 | 03:42 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
<font face="Verdana, Arial" size="2">Originally posted by clemsparks:
</font>
Really??? Well I am in search of an AC delete heater box so I will have to check that out - I just happen to have an S10 without heat to look at as well (my daily beater)!! I'll let ya know if it looks like it will work, but I am sure it would require a few trimmings and drillings even if it will - not that it will stop me from using it, but some of you guys want the totally clean factory look, so..........
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Nov 7, 2001 | 05:47 AM
agawam's Avatar
I have an 86 T/A with AC and just pulled the whole unit out of an 86 non AC camaro but you say that only an s10 will work why won't the f body swap it's the same chassis and same year
Old Nov 7, 2001 | 07:32 AM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
<font face="Verdana, Arial" size="2">Originally posted by agawam:
...but you say that only an s10 will work why won't the f body swap it's the same chassis and same year</font>
WHOA HOSS
I said:
"I've heard that an S-10 heater-only setup will work. I have not verified this, and it may only be in reference to the firewall side of things. I'm not sure."
I was talking about a "heater-only" setup (i.e. NON a/c) coming from an S10.
I didn't say that the S10 is the only way to go. Furthermore, I'm not sure that it will even work. I was just told by someone that he had "heard" that it would (or might).
Again, I have reason to believe that this person was only referring to the pieces on the firewall side of the system (the box that houses the blower motor).
Matt, definitely take a look at it and see what yo think!
Clem
Old Nov 7, 2001 | 11:04 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Matt if you could let us know, that'd be great! I've pulled my A/C, but left the evaporator in the box on the firewall... if I could swap over a "heater-only" firewall box, I would.. but I've never seen a "heat-only" F-body in the yards around here. I've seen plenty of S10's, though... and never gave 'em a second glance.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 7, 2001 | 01:10 PM
Danger's Avatar
Car: 84 TA
Engine: 305 L69
I found it easy to remove everything, but one advantage to leaving the stock controls in is that it provides a manual control over your radiator fan when in traffic, at least in my car. Just select any of the ac options and the fan kicks in. I wouldn't want to loose this option.
84 Trans Am HO L69 WS6
5 Speed manual
Vortech Cherrybomb no cat
JB Headers
Comp Cams XE262H-10
Removed A/C A.I.R. Hdflap
H/made tri cld air induction
K&N
Otherwise STD
Currently painting
Old Nov 7, 2001 | 01:32 PM
snakeskinner's Avatar
I've had the same results as TomP looking for a heater box. I'd like to delete the a/c on my 86 but can't find one. My friend has a 7500 car salvage and he doesn't even have one.
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
73 bronco
2000 Ducati 996 Monoposto
Old Nov 7, 2001 | 01:50 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
I didn't think they were that rare. Think of all the V6 stripper cars there were out there. Maybe the problem is that all the yards are only stocking new stuff (the big name ones it seems are doing this) and there's not much early thirdgen stuff around. Idunno?
Old Nov 7, 2001 | 02:02 PM
iroc5speed's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Danger:
</font>
well I already have wired up a manual switch, so that's not a problem for me. I just want to get rid of all that crap under there that I don't use, and put in heater only controls so it will look correct.
Old Nov 7, 2001 | 02:07 PM
Danger's Avatar
Car: 84 TA
Engine: 305 L69
Does the manual switch look correct?
Old Nov 7, 2001 | 06:13 PM
well, since about the mid 70's, about every vehicle sold in Oklahoma has a/c being we see many 100degree plus days through the summer. I may have to find a northern yard to get one.
Kyle Osterholt
Okarche, Oklahoma
86 T/A 383 TPI
80 T/A Pace Car
73 Opel GT
73 bronco
Old Nov 7, 2001 | 07:19 PM
iroc5speed's Avatar
Does the manual switch look correct? </font>
I took the tray out of the ash tray and put in a piece of plastic as a switch panel. I flip the lid(and it's strong, stays in place, I'm amazed because I've never seen a tight ash tray door on a third gen)and the switch is on the panel. I think it's pretty sweet.it's also out of view unless I open the ash tray door
Old Nov 7, 2001 | 08:15 PM
MeanYellowZ's Avatar
As far as I am concerned, the S10 setup wont work without considerable modification. Stick with the camaro setup.
Always a sucker for posting a pic, heres one of the old cars engine with heater only box visable in the background
<img src=http://members.aol.com/rcyi980/myzengine.jpg>
Old Nov 7, 2001 | 10:28 PM
iroc5speed's Avatar
wow looks nice and clean. now I can't wait to take mine out! I'm gunna wait til it's not cold anymore though, in case something goes wrong. At least I'll have heat when I need it.
Old Nov 8, 2001 | 01:20 AM
Matt87GTA's Avatar
OK. I looked at my '85 S10's non-A/C heater box (underhood part). It looks like it just might work. It is a one piece unit that is the same length as my GTAs box and appears to be the same height as the one on the GTA (pretty hard to say on the height with both boxes mounted on the vehicles..). I think it will work! The one on my S10 appears to be the same as what is in MeanYellowZ's picture too...... It is a one-piece unit and the blower resister module is in the exact same spot as his.... The downside would be that they appear to not accept the same blower motor assembly...
Question to MeanYellowZ: Did your car originally have A/C from the factory? I ask because the firewall may be cut differently for A/C and non-A/C cars.......
Either way, I would put good money on the fact that an S10 non-A/C heater box would be able to be slightly modified to work if it doesn't, in fact, bolt right in!!
Well, I would appreciate some more info on this if anyone has any rock-solid results on if it will bolt right in or not........ I just might set out in search of one for cheap out of a junkyard and give her a go over the winter.....
1987 GTA L98 MD8
My GTA
Old Nov 8, 2001 | 06:27 AM
iroc5speed's Avatar
well I can tell you that you do eed a new blower motor for the heater only setup. If I can find a donor car I'm just going to pull everything hooked up to it out and transplant it.
Old Nov 8, 2001 | 08:49 PM
The S10 box will not work as far as bolting in, it may work with modification, and i believe it will leave some of the firewall holes visable by a little bit, requiring some filling. My car was an A/C car that I changed over with a junkyard Camaro heater only box.
Old Nov 8, 2001 | 10:02 PM
leirch's Avatar
Here is a picture of my non-ac box.
Here is another with the rest of the "stuff" in the bay
[img]
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
[This message has been edited by leirch (edited November 08, 2001).]
Old Nov 8, 2001 | 10:24 PM
iroc5speed's Avatar
looks good, now I know what to look for when I'm at a yard. Great pics!
Old Nov 8, 2001 | 11:38 PM
BTS88IROC's Avatar
Leirch - Now that I've seen a AC delete box that looks like ALOT like the heater only box i had on my 67 camaro.....i still have it actually.....anyone want me to post a picture of it?
Old Nov 9, 2001 | 01:16 AM
Matt87GTA's Avatar
Well now that I got a good look at that F-body one (thanks Leirch) it looks as though the S10 one will be a bit of a project to get it to fit.... It appears to me to be longer than the F-body one in the part that goes over the heater core, right where the Evaporator would normally be. The S10 one kinda drops down there to a spot that looks to be a bit lower than that F-body box..... It is shaped pretty much the same so you could definately get it to work with a little bit of fabrication. And if you were careful when you fabbed it up and painted it nice before the install, it would look totally OEM......
I might still get one and work it over a bit this winter. We really have nothing to lose since the right one from GM is discontinued and a used one is pretty hard to find out of a junkyard since most F-bodies had A/C....
1987 GTA L98 MD8
My GTA
2012sergen11
Oct 13, 2015 07:38 PM
Nervous2
Oct 8, 2015 10:53 PM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
Ironhead38
Sep 7, 2015 02:26 PM
