500+ hp engine combo
Old Nov 7, 2001 | 05:58 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
ok...what can i do to build a 500+ engine, the cheapest way? what heads/cam/intake would provide the best results?
350? 355lt4? 383 stroer? 403 stroker?
it also needs to be able to withstand a say, 150-200hp hit of nitrous.
all i need to do, is run a 10.39...got a little bit of a grudge match with a friend in germany who is running a 10.4 with a 435ci with is getting about 680hp
thanks
lt1, -smog pump, -ac, descreened maf, tci valve kit, fairbanks billet servo, 12pack of killians, hot red head.
***usa's fastet KITT, somday....***
Old Nov 7, 2001 | 06:54 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Go to the AirFlow Research internet site and check out their chevy smallblock combos
using AFR heads and intakes. This will give you an idea... You'll also need a bullit proof trans/converter and rear end setup.
Old Nov 8, 2001 | 03:44 PM
gruveb's Avatar
Car: 1989 IROC-1
Claims by people who sell a product are always a little padded.
Your best bet would be to build up a 400.
I'm looking into doing the same thing...my goal is about 550 ponies or so, good idle, and all of that good stuff.
http://www.gruveb.com/z28
Old Nov 8, 2001 | 04:12 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
To run 10.4s on the motor in a 3600lb car you need more than 500engine hp. You need almost 600hp. I hope your planning on using the spray to get that number.
If this is a real LT1 combination, your looking at something like this.
http://phil.tobin.net/Hoover/top.html
Otherwise, think about a real 400 small block with 18degree heads.
[This message has been edited by jcb999 (edited November 08, 2001).]
Old Nov 9, 2001 | 09:05 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
I'm looking at getting 5-600hp n/a...and then, throw some juice or boost on top to get really wild
Azrael91966669
25
Jun 20, 2017 04:04 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
nuggie
Aug 25, 2015 01:27 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
