406 engine
Old Nov 8, 2001 | 07:15 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
406 engine
I'm thinking about buying an 84 camaro which has a 406 engine in it. Just how exactly is a 406 engine made? All i know about it is that its a built 4-bolt small block and it makes 383hp and 465 lbs of torque. Is it a destroked 454 or a stroked 350 or what? It has a holley 750 carb on it, but i'll probably put a brand new holley 670 avenger carb on it because the 750 needs a rebuild. Just how streetable do you guys think a motor like this would be? Its going to be a daily driver. I'll try and find out some more specs on it such us the cam size and heads, but i probably wont be able to for a few days. (it has a T5 tranny behind it which is very suprising and the car runs 13.6 in the 1/4)
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, no cat,SLP 1 5/8" headers and y-pipe, March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears(open), Ultimate TBI Mods,AFPR,MSD(ignition,coil&wires),Edelbrock TBI Manifold, 190ltr/hr fuel pump,
Eibach springs with KYB's all around,
Centerforce dual friction clutch, 5spd,
0-60mph-7.0s-Gteched
Old Nov 8, 2001 | 08:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
406 is a 400 bored .030 over.
Old Nov 8, 2001 | 09:28 PM
GOLD85's Avatar
lake said above a 406 is a bored 400 wichg is a small block. a fore bolt main block are pretty hard to come by. a 400 is a very streetable motor, lots of low end torque, youll be very happy with it
when the green flag drops the bull$hit stops
Gold 85 Camaro with no motor, pulled the 2.8 to make way for a 350 wich was pulled this summer because a 406 will replace it. The 406 sports a stock bottom end with ARP bolt holding it togeter, flat top hyper pistons. Comp 282 solid cam(.528 lift with 1.6 rockers) Savin up for my Sportsmen 2 heads right now. still Have the perf RPM and 650 DP i used on the 350. Headers and 3inch exhust. Shooten for mid to low 12s next summer
Old Nov 9, 2001 | 05:40 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The two bolt 400 is generally thought of as more desirable than the four bolt.
Old Nov 9, 2001 | 06:13 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
Sounds like the heads are keeping the hp down. It should be able to make 420 no problem with good heads.
Old Nov 9, 2001 | 09:48 AM
bradkeith's Avatar
Apeiron and gold85 were both right. a 406 is a small-block. I am in the process of builing a 400 smallblock (2 bolt) but and going to use a 3.75 stroker crank with 6in rods and offset pin pistons to make a 429.
to reply.. the 4-bolt 400's were prone to stress cracks around the front main cap due to the main bolts being close together. That's what the guy who did the block work on my motor told me.
1986 camaro with 92z28 gound effects, aero wing, 17in American Racing Pythons w/275'40's 4 3/4 Unlimited products cowl, 3.90 auburn gear rear-end with Steve Spohn adj LCA's,Panhard bar. 406 stroked to to 429 motor in the works.
1989 Iroc-z 5.7 white t-tops, 3.42's megashifter, 2 1/2 harwood cowl.
Old Nov 9, 2001 | 02:01 PM
SoCo80p's Avatar
3.75 is the stock 400 stroke
Old Nov 9, 2001 | 03:11 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
to make a 429 you'll need to bore it .010 over and find a 4.00 in crank .good luck anyways...........be careful of the thin cylinder walls if you go .030 or more......................
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,slp 3in. catbcak,a/c delete.
SHE IS GONE BUT I KNOW THE GUY WILL GIVE HER A GOOD HOME.
best e/t:
3653lbs./full tank+ driver.
14.10@96.53mph 2.01 60'
Old Nov 9, 2001 | 03:37 PM
Mojo's Avatar
<font face="Verdana, Arial" size="2">Originally posted by PETE:
</font>
Mine has been doing well at .040 over.
408cid 1985 Corvette
http://www.mojosgarage.com
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
