How to tune a carbed engine...?
Old Oct 6, 2005 | 04:35 PM
tilstad's Avatar
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
Well, the thing thats nagging me is how do those magazine guys tune their engines.. I'm not talking about jetting and timing, I mean how do they tell what to do?
How can you tell on a carbed engine like " Oh yeah, a #2 bigger jet and 4 degrees more timing will give us 20 more horsepower...."???
Do they use wideband O2 sensors, or just read the plugs and listen for knock?
Old Oct 6, 2005 | 05:06 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
they stick an O2 in the tail pipe and hook it up to an A/F meter to tell how to tune it. Magazines usually have ties with dyno shops so they prob dyno it after a change, or they might do some math calcs.
Old Oct 6, 2005 | 10:12 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I would think they go to a dragstrip, make sure they can drive it very consistantly, then do one change, note the speed dif, then either go in that direction, or away from it (if it makes it faster or slower.)
and/or O2 sensors of course...
also reading the plugs is for the real old school guys.... ie the ones using carbs instead of a wideband O2 sensor and fuel injection (cheaters)
Old Oct 7, 2005 | 09:34 AM
wrightz28's Avatar
Car: '88 GTA,'85 z28
Engine: L98, LB9
Transmission: 700 r4
Axle/Gears: sleepy 3.23, hello 3.73
Hey, I resemble that statement
It is a tried and true "old school method".
I still trust my senses more than a damned cpu anyways on my tpi. On my carbed cars, all of the 5 senses but taste go into tuning them, how they sound (after years, you know the sound of a healthy motor, half the time I don't even use a timing light anymore) and tuning carbs (and dizzy adv. weights) is basically plug reading, how the motors sounds and reacts to throttle and how she smells.
Old Oct 7, 2005 | 01:03 PM
jimmy_mac's Avatar
If I got smoke coming out the tail pipes when I hit the throttle, I try to go leaner. If I start pinging I make sure I'm not to crazy on the timing and maybe fatten the jets a little. How's that for some high tech tuning.
Old Oct 7, 2005 | 01:41 PM
Sonix's Avatar
Car: 1982 Trans-Am
Pardon?
Old Oct 7, 2005 | 01:49 PM
wrightz28's Avatar
Engine: L98, LB9
C'mon, more old school talk, little stooges is a neccessawy.
As Curly would say, hey, I resemble that statement.
I know hard ot depict through text, some get it, some don't.
Old Oct 7, 2005 | 02:15 PM
chesterfield's Avatar
Car: Pontiac
>>>C'mon, more old school talk, little stooges is a neccessawy.>>>
you better go back to school. "I resemble that remark" ...Groucho Marx.
Curley would have said "If at first you don't succeed, keep on sucking until you do..." I think he was talking about tuning carbs.
Old Oct 7, 2005 | 02:19 PM
wrightz28's Avatar
Engine: L98, LB9
ohhhhhhhhhh yeahhhhhhhhhhh.
Old Oct 7, 2005 | 02:24 PM
Car: 88 Camaro
Engine: 310 LG4
Nuk Nuk...
going to kill myself for saying that now.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
makaveli09
Sep 15, 2015 10:43 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
