Cant Rev Past 2000 When Doing a Burnout
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
I drop it into 1st, powerbrake, and floor it. It revs immedietly to 2000rpm and stays there. When I let off the brake and start moving forword the rpm's pick up to about 4000, then I let off. Is it just cuz I have 2.73's?
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You must have the infamous traction control option.
Your torque converter has a stall speed of approximately 2000 rpm. So your motor will only tach up to 2000 rpm and then the car will start moving.
I didnt think any 3rd gens had any type of traction control device. Dose that option show up in the RPO's? How do I change it?
See I new there was no such thing as traction control on 3rd gens. My frickin LO3 would do burnouts to 4000rpm while powerbreaking. How can my LB9 not? Its got 40 more HP and 30 more ft. pounds of torque
Now that I think about it, even my 2.8 would rev to whatever I wanted it to go to when burning out. Are all LB9's like this?
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
My LB9 would rev up to whatever I wanted when I was doing a burnout.
I usually brought it up to 3500 or so
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
As ME stated, you're going up against the TC.
I tried doing a burnout with my new powerplant. I blew out my rear end.
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Even with a higher stall torque converter, you should be able to rev past that with enough throttle.
Does the car have a 2-stage rev limiter by any chance that a previous owner may have installed?
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Shake Zula- We need more power scotty
Car- I cant do er cap'n
It could have a bit to do with those high gears in the rear but i would think it would still do better than that.
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
most likely he has rear disc, good rear tires and a tired eng.
I remember those old lg4 4 wheel disc cars you could watch the rear tires barely turn over
Car: Z28
Engine: Sb2.2 406
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
I loved flash blizzards when I lived up north -- I'd be the only guy on the road doing donuts in the fresh snow.
No rear disc brakes. Engine has 39K original miles. Went from a 45mph dig with a Camaro that runs 14.3 stayed right beside him clear up to 95mph, so its running good. It cannot be a matter of not enough power. Once I let off the brake the rpms pick up while the tires are still spinning.
Car: Z28
Engine: Sb2.2 406
Sounds like you have a fully functioning automatic transmission and braking system.
I was thinking good brakes+ good tires. There P245 Eagle GT 2's. Im gonna try breaking them loose, let the car move forword so it revs, then powerbraking. Like I said it has no problem keeping up with a low14 sec car going from a pull, so its running good, cant complain too much.
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
I gott ask,
Why are you so worried about powerbraking this turd?
obviously traction is ample,so there's no need to heat the tires.
So my suggestion is,STOP IT DUMMY!All your gonna accomplish is melting down your tranny.
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
He wants to be cool like me and make a intersection have zero visibility
Not that i would ever do anything dumb like that
It is purely a lack of power or over braking, so either let up on the breaks, get a line lock or start working on the motor.
Car: 1983 G20 Chevy
Transmission: 4L60
Originally posted by stonedchihuahua
let some pressure off your brakes, cars can be very finiky when attempting to do break stands if you don't have a huge amount of power and good breaks.
Better yet, get a line lock.
Nothing like filling a riced up honda with his girlfriend in the car with tire smoke, with a van no less. Joined: Dec 1999
Engine: ls1, LB9
Originally posted by Stekman
Unless he lives up north, when burnouts are seasonal.
gixxer92
May 18, 2017 11:20 AM
