Compression Ratio?
Car: 99 Formula
Axle/Gears: 342
Compression Ratio?
Is there a way to raise your compression ratio without taking off the heads, I don't think there is but I was just wondering.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
With the motor upside down, remove the oil pan and remove all the main bearing caps
and connecting rod caps. Carefully lift the crank out of the block. Have the crank offset ground (machine shop).020" on the rod journals.
Reinstall the crank with .020" undersize rod bearings, being carefull not to nick the journals with the rod bolt ends. Button up the oil pan.
This would increase the crank stroke .020"
and raise the compression about .3:1 on a 350
without removing the heads.
[This message has been edited by F-BIRD'88 (edited November 13, 2001).]
Car: 99 Formula
Axle/Gears: 342
Wow, so should I just flip my car over too. Just kidding, I was wondering because I have a warranty on my motor and I'm sure pulling the heads would negate that warranty. Thanks for the info though.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Actually, if you flip it upside down you could just unbolt your motor mounts and then unbolt the crossmember, then you could get right to the oil pan!!
I think you should give it a go
Brendan
Brendan
Car: 82 Trans am
Engine: Twin turbo 350
F-BIRD'88s idea would actually increase the stroke by .040". It would add .020 to both the top and the bottom of the stroke, and therefore give you twice the compression increase. THis is almost becoming worth the hassle
hmm, maybe if u somehow got alot of carbon to build up inside the combustion chamber really quickly.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
- David
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
