Valve cover leak
Old Nov 14, 2001 | 11:38 AM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Axle/Gears: 3.23 Posi
Valve cover leak
Hi guys, I have an 86 IROC w/ the perimeter bolt design stock valve covers. Well oil traces are coming out of all of the bolt areas on the covers and I was wondering if I need new gaskets or something? Is this common? I am not losing any great amount of oil between changes but I just want to fix it for appearance purposes. What are the torque specs? Thanks!!!
Old Nov 14, 2001 | 12:11 PM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
If you're lazy, you can try to just tighten all the bolts (in case one or two is loose). Otherwise, just replace the gaskets (may as well do em both at the same time). Gaskets are cheap. You'll have to do it sooner or later and if you're careful and keep the mating surface clean, you probably won't ever have to worry about any oil leaking again.
You can find the torque specs in the Haynes manual - I don't know them off hand. The valve cover bolts are ones I'd actually pay close attention to the torques - overtorque and you can strip threads (speaking from experience here... not fun to do the whole helicoil bs), undertorque and oil leaks...
Joel Geerling
Red 91 Formula, 305 TBI
Edelbrock 14x3 open element
TBI 1/2" spacer
Hypertech street chip
Crank/Alt Pulleys
Exhaust is next!
Old Nov 14, 2001 | 12:24 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
I think they get torqued to 30 lbs.Fix it as soon as possible,you dont wanna get any oil on the freshly polished runners.
Oh yeah have you taken any pictures yet?
Old Nov 14, 2001 | 12:32 PM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Hey Mike how is it going? Yeah I gotta check into the specs of the torqueing I guess. I am gonna get in touch with you again this spring. Thanks guys for the replys!
Old Nov 14, 2001 | 01:14 PM
FAST85Z28's Avatar
my haynes manual says - Rocker Arm Cover Bolts 75 in-lbs... that sounds like alot?
~1985 Camaro Z28~
V8,305,700R4,K&N Edlebrock Air Filter,& MSD 8.5MM Super conductor Wires,
Old Nov 14, 2001 | 01:41 PM
iroc5speed's Avatar
get new gaskets. those'll run yp to about $20 for decent ones, but you'll be happy you spent it.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
db057
Sep 4, 2015 07:57 AM
Thaney9
Aug 29, 2015 03:16 PM
NBrehm
Aug 25, 2015 11:49 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
