Car runs like crap and stalls
Old Oct 16, 2005 | 03:29 PM
smokenasty's Avatar
Car: 87 Iroc
Engine: 5.7 TPI
Transmission: Automatic
i just recently replaced the altenator in my 92 camaro RS because the battery wouldn't hold a charge and would drain. Well now the car starts up fine but then when i'm driving it stalls out and the service engine light comes on. Also at this time the engine temp is up to about 240. Is the car stalling because of the engine overheating. If so i prolly need a new thermostat then and how hard is that to replace myself.
Old Oct 17, 2005 | 06:52 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
Check to see if your cooling fan is running and check to see if the air deflector under the front of the car is missing. It hangs down and is easy to smash off on parking curbs. I have a friend who had a car like yours and he had to turn on his a/c to get the cooling fan to run.
Old Oct 17, 2005 | 10:16 PM
smokenasty's Avatar
Car: 87 Iroc
Engine: 5.7 TPI
ya the air deflector is there. I replaced the thermostat and it doesn't overheat now...but it still sounds like its not running right..and when i accelerate it feels like it bogs down and misses gear.
Old Oct 18, 2005 | 06:47 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
boging usually means it's running rich, ignition timing could be off also. By misses gear do you mean shifts up to early, if so it could be the TV cable is out of adjustment.
Old Oct 18, 2005 | 08:30 PM
smokenasty's Avatar
Car: 87 Iroc
Engine: 5.7 TPI
ya it shifts up to early and then the engine slows down to catch up to the car..its an auto just to let you know
Old Oct 20, 2005 | 06:42 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
Do you know how to adjust your TV cable?
Old Oct 20, 2005 | 07:33 PM
smokenasty's Avatar
Car: 87 Iroc
Engine: 5.7 TPI
no but if its not hard then i'm pretty sure i could do it
Old Oct 21, 2005 | 08:40 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
There is a tech article on this website under transmission called adjusting your TV detent cable, they do a better job explaining it than I could in a post.
9192camaro
16
Feb 3, 2019 12:21 AM
Wade787b
Sep 29, 2015 01:15 PM
kyleb24
Aug 15, 2015 08:24 AM
TreDeClaw
Aug 14, 2015 06:58 PM
Kaweh
Aug 9, 2015 02:54 PM
