Can somone explain the knock sensor ? (kinda long sorry)
Old Nov 15, 2001 | 03:29 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
Im new at engines, but from what i read in the archives the "knock sensor" detects vibration, and pinging type noises. If there is a knock it retards the timing to save pistons and drivetrain parts. Now here's my questions
Question # 1 "If i had bad motor mounts could it set it off" ?
Question # 2 "how often if ever do knock sensors go bad" ?
Question # 3 "at idle my car read 12 degrees on the timing scale (propperly warmed), and it seems as if it's "loading up" all the time. Could bad timing cause my rough idle, and hestiation,(isint it supposed to be 6 degrees at idle?)
Question # 4 "how do i go about changing the timing if it's computer controlled" ?
Old Nov 15, 2001 | 06:33 PM
Guest
Guest
Posts: n/a
I'm gonna do this the easy way:
Depends on how bad. If they are so bad you are getting some sort of metal-metal contact then yes it can set it off.
I'm not aware of any life span of the sensor.
It sounds a little low actually. The computer advances the timing at idle, so you wouldnt see 6 unless you disconnected the wire to set the timing.
Only thing you can control without reprogramming is the base timing. To set that you have to disconnect a single wire weatherpack connector thats on the passenger side of the engine compartment, sitting above where the heater/ac box is. Its tan with a black stripe. Then it should read 6, or someone may have bumped it to 8 or 10, which should be ok.
Chuck84TA
Jul 15, 2016 09:05 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Thaney9
Aug 29, 2015 03:16 PM
