valve cover torque
Old Oct 20, 2005 | 10:57 PM
vadimz28's Avatar
Car: chevy camaro 1987 z28
Engine: bored out 305
Transmission: t-5
valve cover torque
i jsut got some new valve covers and i cant find the chilton manual to tell me the torque that they should be on there any1 have that information or somewhere online i can find it? thank you
Old Oct 20, 2005 | 11:28 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
not too tight, but not loose either.
it's not a critical thing. Just tighten them a bit so they snug down, but not overtightened so that you warp the gasket surface. Use RTV on the valve cover side, and throw on a re-usable FelPro gasket on each.
Old Oct 20, 2005 | 11:38 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
i use a socket on a screwdriver style handle, works good as theirs pretty much no way to over torque them that way.
Old Oct 21, 2005 | 01:07 AM
vadimz28's Avatar
Transmission: t-5
yea i got some real nice felpro gaskets but dont know what rtv is, right now they are jsut hand tightened on there, thanx
Old Oct 21, 2005 | 01:12 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
RTV is silicone sealant. I believe that the book sas tighten to 12-15 ft lbs. If you have aluminum heads. 12 ft lbs max. Anything higher WILL require helicoils.
Old Oct 21, 2005 | 06:29 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Use a nut driver (like a srewdriver with a socket) and go hand tight. That'll be enough. Actual spec is like 6 ft-lbs or something.
Old Oct 23, 2005 | 08:51 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
if you have the standard sbc heads a neat trick is to use rtv on the top of the gasket and a thin later of axle grease on the bottom.
the valve cover is easier to clean than the head.
there is also the possibility of reusing the valve cover gasket(if you remove the valve cover carefully!)
the grease prevents leaks suprisingly effectively!
the rtv holds the gasket to the valve cover's smoother gasket surface.
i haven't tried the new silicone rubber ones yet,but hopefully soon!
i'll post results when i try them
Eric B
Old Oct 23, 2005 | 09:23 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
i have the reusable ones on mine. i don't use any silicone/rtv either. 3 years since i have had them off and no leaks. the nut driver/hand tight works great.
Old Oct 23, 2005 | 10:47 AM
Tibo's Avatar
Car: 1991 Z28 Vert
I have used the reusable ones for a year now and had the valve covers off and on many times. I haven't had it leak yet.
New2Chevy
Sep 28, 2015 12:35 AM
angel2794
Sep 8, 2015 06:22 PM
Thaney9
Aug 29, 2015 03:16 PM
NBrehm
Aug 25, 2015 11:49 PM
mustangman65_79
Aug 8, 2015 01:18 AM
