oil coming out of starter bolt hole
Old Nov 17, 2001 | 04:26 PM
JunkHead84's Avatar
theres oil coming out of my starter bolt hole and i think its causing the starter not to engage right. it makes that bad grinding noise. help the car is sitting in a parking lot. thanx
Old Nov 17, 2001 | 05:25 PM
killer305's Avatar
huh, what kind of engine do you have, i have no clue how oil could come out of the starter, are you sure its not the rear seal , and are you sure its oil
90 RS 305 tbi, 4 3/4" cowl Hood, Edelbrock TES headers, Flowmaster exhaust, Crane roller cam, comp roller rockers, vortec heads/intake, ported tbi, w/new injectors, MSD probillet Distributer/ coil, 1 inch tbi spacer, air foil, 14x4 k&n flat base air cleaner, Rebuilt 700r4 w/ B&M shift kit, B&M Megashifter, 3.23 posi, 2 12 RF's with mtx amp, top of line alpine cd player, soon to have 90-91 gfx, z-28 wing, new paintjob, rims, and all new lowered suspension.
Old Nov 17, 2001 | 05:31 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
The oil is NOT coming out of the bolt hole... it can't. What's happening is you have oil leaking from somewhere else onto the top of the starter and it's running down the starter so that it "appears" that it's coming out of the hole. Blown rear main seal, blown head gasket, cracked block.... any of these things could be possible.
1986 Trans AM
355 TPI
4 Wheel Disc Brakes
9 bolt Borg Warner Rear (2.77's....oh joy) :P
6" rods, approx. 9.7:1 Compression, Stock TPI (soon to be ported), 24#/hr LTI injectors (cleaned and flowmatched by Cruizin Performance), Hedman Shorty Headers, 3" exhaust with 80 series flowmaster, SBC 993 heads completely redone and modified for 1.6 RR, 1.52 RR (for now), Comp Cams XE262-14 TPI Cam, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Ignition, Hypertech 53,000 volt coil.
Track times to come.
Old Nov 17, 2001 | 05:38 PM
rezinn's Avatar
Check your dipstick tube, I believe it is right above the starter.. that would be my best guess.
Old Nov 17, 2001 | 05:52 PM
killer305's Avatar
yeah i would say the oil tube, i know on my block the tube comes out right above the starter 86tpitransam is aboslutly right about the bolt hole. once i broke off both the starter bolts in the block and had to drill them out, so i too am absolutly sure that there is no way oil cam come from there uless your block is cracked. whats the problem, it dosnt start, if it does throw in some oil, and bring it back too your house.
Old Nov 17, 2001 | 08:22 PM
age's Avatar
age
Car: 1992 Z28 1LE
try the rear main seal. Remove the inspection plate, and you'll know..
Old Nov 18, 2001 | 07:13 AM
JunkHead84's Avatar
even if its coming from somewhere else could oil getting on the starter cause it not to engage properly. the engine is an 86 350 crate motor, the dipstick tube is on the other side.
Old Nov 18, 2001 | 07:51 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The oil is not coming out of the starter bolt hole, and it's not causing the starter to malfunction. I don't have to see the motor to know that.
Is this a mid-70s 350? If so, you have the usual thing that we all ran into at one time or another back in those days. Your block is incorrectly machined.
Do a search of all the boards for my posts containing the text "4347". I've gone over this issue in detail many times, but I don't feel like typing the whole explanation and cure all over again.
ICON Motorsports
84z96L31vortec
Aug 20, 2017 12:16 AM
mhatfield 14
Oct 24, 2015 07:48 AM
Navy8125
Aug 21, 2015 09:32 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Elliswon
Aug 10, 2015 12:33 PM
