valve guides
Old Oct 25, 2005 | 08:24 PM
TOM 85T/A's Avatar
valve guides
On the carbed 305 can the the guides be replaced without removing the heads?( Sorry my mistake meant to say valve seals)
Old Oct 25, 2005 | 08:29 PM
z28 NyC's Avatar
Car: 1986 Camaro z28
Engine: 305 tpi/light mods
Transmission: 700r4/ B&M mega shifter
Iam pretty sure everything but the valves themselves can be taken out without removing the heads ofcourse it makes the job more difficult but definantly possible.
Old Oct 25, 2005 | 09:25 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
No, you have to pull the heads to replace guides. They have to be completely disassembled and cleaned first.
Old Oct 25, 2005 | 09:51 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Valves and valve guides need the head removed. You can do valve seals and springs with the heads on.
Old Oct 26, 2005 | 04:30 PM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
Re: valve guides
The seals can be replaced on the engine by either using the rope trick, or using an air fitting that uses compressed air to hold the valve up.
Old Oct 26, 2005 | 07:58 PM
demonband2000's Avatar
Could you fill me in on the rope trick?
Old Oct 26, 2005 | 10:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Stuff a length of nylon rope into the spark plug hole to fill up the combustion chamber to hold the valves up.
Old Oct 26, 2005 | 10:32 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Just leave the end of the rope hang out so it can be removed
69GTOby
Apr 18, 2016 02:34 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
