K&N Air Filters - A good Thing?
Car: got 5 which one?
Engine: V8's what else
Transmission: Auto/4spds
This should raise some ****, I have a 87 GTA with a 350 TPI. IT came with a K&N air filter and ram air box. The previous owner stated that the Filter had not been charge for a while. So I buy the recharge kit, follow directions and instal 2 days later. After driving it for a few miles the SOS light comes on. Throws a MAF Sensor code. So I talk to a few folks including my mechanic friend and he states I wish people would quit putting K&N filters on cars with MAFs, everytime I get one in here witha a MAF light I tell them "Well you spent a fortune on the K&N setup but sometimes it ruins the MAF.
Nice so I pick up a new MAF at Autozone and a "Dry" Fram Air filter. Install it and havn't had a problem since. Coincidence??? I don't think so the previous owner just put a new MAF in a week before I bought the car.
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Its the oil, not the filter. User error doesn't make an inferior product. Clean off the MAF before replacing it.
Read my post again, I followed the directions exactly. Even let the filter sit out for 2 days, sorry no user error here.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
well lets give this post a little bit of time, and see if anyone else mentions that, 'cuz on this forum there's TONS of people with factory FI (MAF and otherwise), and I imagine K&N being at the top of the popularity list...
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
So what else failed the MAF? The extra air? No! It was the excessive use of recharging oil that got on to the MAF and destroyed it. The the only feasible thing that can ruin it. Nothing else..
Car: 89 IROC-Z
Axle/Gears: 2.77
I have the K&N setup on my car. One day I started it up and I got the MAF code. I talked to the previous owner and he said since it was an unscreened MAF, (don't know if yours is)sometimes the system just sort of freaks out. I disconnected the batt, reset the comp and never had a problem again. The only other time it ever threw that code was when I ran the motor w/o the snorkel thing that comes out the front of the TPI and it did it b/c I didn't have the MAF plugged in. I would say the way to tell if it was a freak thing, or something constant, would be to try the K&N again, after washing it with soap and water, and see if the same thing happens. When you oil it, make sure the REALLY LIGHT coat of oil goes on the side where the air comes in to the box, not the side going into the motor - not saying thats what you did BTW. If you have your old MAF sensor, you could try cleaning it and putting it back in w/ the fram filter. If it works, use that MAF as the guinnea pig not the nice expensive new one. Good luck.
The last time I cleaned and recharged my filter, the kit I had was this silocone stuff for the gasket and an aresol spray can of oil. Just making sure were on the same page. I don't remember anything about letting it sit for 2 days though. Not HERE either
Aggree the oil destroyed. But not having any experience with a K&N and following the directions on the recharge kit, still destroyed it.
Had to turn in the old one as a core
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Originally posted by Sonix
...and I imagine K&N being at the top of the popularity list...
http://www.ls1lt1.com/forum/showthread.php?t=657
You may be surprised at the list on TGO that pass over the K&Ns.
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
I'd strongly suggest you folks set on your K&N filters have your used motor oil analysed after your next oil change and see how much dirt is getting into your engine. Then try a regular paper filter for a full oil change duration and have it checked. Compare the differences.
I will not allow a K&N on any car of mine. Nor would I buy a car if I know it has had one on it any time in it's past. They do make one of the best oil filters money can buy tho.
Car: Tree Huggers
Engine: Do Not
As an aside, our MAFs with the hot wire typically do not fail due to oil contamination from a K&N unless overly excessive. That's what the burn off cycle is for.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
and how much oil did you put on the filter?
Originally posted by rx7speed
oil doesn't dry
oil doesn't dry
Car: 89 gta ws6, Dodge Turbo Diesel, H-D
Engine: 383 4-bolt #638 block
Transmission: 700r4, corvette servo, 2200 stall
Axle/Gears: 3.27 9 bolt b-w, pbr discs
K&N
People w/turbo diesel motors know all too well about maf probs coming from K&N oil application even following instructions to a T There has been many a thread on this topic in the Turbo Diesel Register (tdr1.com) There may be particle test on TGO. I know for sure there are at least 25 different tests by diff manufacturers. I went from 5ppm silicon (dirt) W/ paper element to 34ppm W/ K&N and my K&N is MIA.
1992 Trans Am
May 10, 2023 07:19 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
