Powder coating intake?
Car: 89 gta ws6, Dodge Turbo Diesel, H-D
Engine: 383 4-bolt #638 block
Transmission: 700r4, corvette servo, 2200 stall
Axle/Gears: 3.27 9 bolt b-w, pbr discs
Has anyone had their airgap intake manifold powdercoated? Wondering about the heat for obvious reasons, my guy says that it's ok, anybodygot a hook
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Oh, BTW - I see you're kinda new, so I'll let you know before someone else tears you apart, lol...
The mods on this board get a little irritable when you make two separate threads on different boards about the same thing. Just a heads up.
newbie
Thanks but I was trying to get exposure and I have seen someone get ripped before and I don't want it to be me Once again Thanks I'm learning
Originally posted by Red Devil
So you knowingly went out of your way to annoy people. Great job.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Have I ever really cared?
Besides, he said he knew better.
. Banned
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
To answer the dudes question: I have powder coated my last 2 intakes. I presently run a MiniRam and heat build up is not a problem. I don't think I would install another intake without powder coating. It always looks good and is easy to clean.
www.geocities.com/dzperf
You can purchase some of Edelbrock's intakes powder-coated from the factory. Not sure about the Air Gap. I have had one like that (a Performer), it was clear-coated.
Gasoline affects it. Cleaning solvents (lacquer thinner) remove it. Be aware of that when choosing colors, and in how you care for it.
Car: 92 Camaro RS
Engine: 3.1L V6
Transmission: 4spd automatic
Go for it dude....I am a Powder Coat Tech and the heat isnt gonna be a prob because powder paint has to be heated to 385 degrees to cure.
Half my engine is powder coated because I do it my self at work.
~Bob
~Bob
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
newbie
I didn't say I knew better Red Devil re-read reply to Adam. There is just sooooo much info on this site that it takes Quite some time to find where you need top be as far as posting. I will try to be a better pvt.
Originally posted by PhLaXuS
How would anodizing hold up? Seems like a viable option, off the top of my head.
I've had nitromethane engines in RC cars that get VERY hot, quite a bit hotter than water cooled car engines, and the anodized heat sinks on the heads seemed to hold up just fine.
Hotrodboba400
Dec 10, 2019 07:07 PM
toronto formula
Sep 10, 2015 07:31 AM
rudolphschenker
Sep 4, 2015 02:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
