stroking
Old Nov 2, 2005 | 05:27 PM
Rally Smith's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: Factory 2.73 (unfortunately)
stroking
Will stroking my engine change where it redlines?
Old Nov 2, 2005 | 05:43 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
All other things being equal, a stroker will have the torque more biased toward the lower end of the curve than a std stroke engine. But a cam change can correct that if you want to shift the curve toward the top.
Old Nov 5, 2005 | 05:07 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Just be aware that stroking a motor increses piston speed which means you may have to lower the redline to avoid piston meltdown.
Old Nov 5, 2005 | 05:12 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
The cam plays a big role in where you redline, so even a joe blow 350 can redline at 3k or 8k RPM
Old Nov 5, 2005 | 05:42 PM
dankhound's Avatar
Car: 91 RS
The redline and the powerband are two entirely diffent things. The redline is the maximum safe rpm for a motor. Any higher and you risk engine damage. The powerband is where the motor makes its best power. Which can be influenced many factors. But Streetiron85 is correct about the powerband.
Old Nov 5, 2005 | 07:44 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Heads, cam and intake choices will make more of a difference.
Old Nov 7, 2005 | 09:04 AM
Car: 91 RS
Engine: 305 TBI
I will be running World S/R torquer heads, turbo city tbi, dual plane manifold, headers, 3" exhaust, comp cam (350 tpi cam, suggested by comp cams), roller rockers, etc..
Old Nov 7, 2005 | 11:06 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
are you wanting to stroke the 350 or the 305?
Old Nov 7, 2005 | 11:50 AM
Car: 91 RS
Engine: 305 TBI
It's the LO3 305. I've already been through the hole 350/305
thing. I am going to play with the 305.
junior419
Apr 7, 2025 11:35 AM
randy210
Oct 15, 2015 03:43 PM
dusterbd
Sep 29, 2015 08:40 AM
C409
Sep 23, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
