No power
Old Nov 6, 2005 | 01:12 PM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
Axle/Gears: Borg Warner
No power
HELP,
An exposed wire made contact with a piece of metal in the engine compartment. I saw an arch and heard a hissing sound. Car was running fine now I have no power at all, windows, radio, nothing.
Is it a fuseable link? I do not know where to start. 1987 IROC 5.7.
Please help.
Old Nov 6, 2005 | 03:17 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
First check the battery, then trace the lines from there. Check fuse box, relays, things like that. You'll find it.
Old Nov 9, 2005 | 08:29 PM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
no power
Thanks 85. Strange thing though, my alarm is still workiing and the interior light by the fuse box lights. I checked the fusible link on the starter and I see a very small cut with exposed wire. All fuses are ok. DO you think I fried the battery?
Old Nov 9, 2005 | 08:36 PM
85cmroz28's Avatar
Engine: L69
Take your battery down to Advance/Autozone and get it tested. That way you can rule it out.
Old Nov 9, 2005 | 10:17 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Battery will probably be fine. You've probably shorted something out. Fusible links will stretch when they are blown.....
Old Nov 15, 2005 | 09:05 PM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
Thanks guys . Fusible link replaced now car will crank. I cant get it to stay on though. I changed the spark plug wires and i followed the wiring diagram. Now it smells of gas when I try to start it. WTF
Old Nov 16, 2005 | 07:46 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Check to see if your getting spark to the coil, then to the plugs themselves.
Old Nov 16, 2005 | 07:44 PM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
Thanks, Not that good a wrench. I have test equiptment but do not know how to test the coil an wires. Pls explain
Old Nov 16, 2005 | 07:48 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
its probably best to just take to coil downtown and have it tested at the parts store. Then if its dead youll kill 2 birds with one stone
Old Nov 17, 2005 | 06:52 AM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
Cool, Thanks
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
